K75 will not start
Topic: K75 will not start (Read 4017 times)
keith g
Motobrick Curious
K75 will not start
January 16, 2014, 11:28:56 AM »
ok........i replaced the fuel pipes from the regulator to the tank and the return,did not disconnect the MAF,just left it hanging,got good pressure from the pump......got sparks.......still won't start.......any ideas welcome......
UK
1985 K75c
K75RT Keith
^ Proficient Motobricker
Re: K75 will not start
Reply #1 on:
January 16, 2014, 02:23:31 PM »
Try reseating the connector on the computer, then check for voltage at the injectors
1990 K75RT
Inge K.
Reply #2 on:
January 17, 2014, 12:06:04 AM »
I would like to add that voltage is only present at the injectors when you press the starter button..........
or the engine is running.
But as your fuel pump is running you probably also got voltage at the injectors....powered from the same relay.
The signal to the injectors is on the ground side.
Norway
keith g
Motobrick Curious
Reply #3 on:
January 17, 2014, 01:07:40 AM »
ok.....thanks guys i'll look at that today ...cheers :2thumbup:
UK
1985 K75c
keith g
Motobrick Curious
Reply #4 on:
January 17, 2014, 05:16:07 AM »
OK.......between you guys and Frankenduck's repair PDF......i have to confess...i'm an idiot...!!!
i cross connected the fuel pipes........DUHHHHHH!!!!!!!!!!!
UK
1985 K75c
K75 will not start
