Author Topic: Alternative Spark Plugs ~ original poster wmax351  (Read 29205 times)
Offline szabgab
Re: Alternative Spark Plugs ~ original poster wmax351
« Reply #25 on: September 25, 2018, 03:24:24 PM »
I have just bought replacement NGK plugs without the terminal nuts as it turns out. The Bosch ones present in the bike are nutted obviously, but can your remove them? I tried with a pair of pliers gently undoing them, but since it did not bulge, I left it be, just in case I brake the damn thing....
  • Budapest, Hungary
  • K75S 1985 model
Offline szabgab
« Reply #26 on: September 26, 2018, 07:40:39 PM »
OK, I will answer my own question, it is not. Don't ruin a perfectly good plug by trying to forcefully unscrew the nut (don't ask, how I know)
  • Budapest, Hungary
  • K75S 1985 model
« Reply #27 on: September 26, 2018, 07:45:32 PM »
I tried with a pair of pliers gently undoing them . . .
You gave up on gently, didn't you?  :musicboohoo: Local mechanics should have a few of those nuts.
Offline szabgab
« Reply #28 on: September 26, 2018, 07:51:46 PM »
Yes, I did  :johnny: . Yesterday I was all reasonable with it, but looking at the net and thinking, I see an XR5DC with a nut removed I went in a bit more forceful. BTW this set of plugs in my bike were the non resistor versions (X5DC), does that matter? Thank you!
  • Budapest, Hungary
  • K75S 1985 model
Offline szabgab
« Reply #29 on: September 27, 2018, 04:20:18 PM »
Dear all, there is conflicting info on whether to use resistor or non resistor plugs on a spark-gap wire (K75), what is the common knowledge on this?
Thank you
  • Budapest, Hungary
  • K75S 1985 model
« Reply #30 on: September 27, 2018, 04:32:06 PM »
My engine's spark plug leads are BMW stock; the 1995 K75 Rider's Manual recommends resistor spark plugs. I install resistor spark plugs after I gap them to the correct spec. I don't try to reason my way through the process any further. :giggles
The BMW Repair Manual for pre-08/1988 motos recommends specifies non-resistor spark plugs.
Offline szabgab
« Reply #31 on: September 27, 2018, 05:17:43 PM »
Hi Laitch,  so that somewhat explains the conflicting info,  K100 lead is a resistor lead,  and probably the k75 leads prior to '88 were too.  I guess measuring the resistance from. one end to the orher would tell me exactly,  what I have...  Thank you for the info!
  • Budapest, Hungary
  • K75S 1985 model
« Reply #32 on: September 27, 2018, 05:30:30 PM »
i use craftsman spark plugs and wiors for their 750cc weed whacker...
you can getts them at sears...
« Reply #33 on: September 27, 2018, 05:33:12 PM »
That's the one that can also be used for stump grinding. Great product!
« Reply #34 on: September 27, 2018, 05:50:19 PM »
you can getts them at kmart...
« Reply #35 on: September 27, 2018, 06:23:32 PM »
The local K Mart closed. I'm using Jaycar exclusively.
