Author Topic: acewell aftermarket speedometer.  (Read 5780 times)
Offline oldfieldcycles
« on: July 23, 2013, 11:45:21 AM »
i have done a bunch of searching, read the k100 cafe racer mod thread which was helpful. i am wiring the same acewell speedometer in that thread to my 95 k1100rs. i have built a circuit to deal with the neutral indicator start issue and i am also building a circuit to use the original speed sensor. here are my questions:
are the pinouts from the wiring harness the same between the 85 k100 and my bike?
there are a number of wires not being utilized in the new instrument cluster. which wires can be completely left out and which ones need to be rerouted.(k100 pinout/wire list at the bottom)
here are the wires not connected to the acewell:
7 white low fuel lamp
8 green/yellow abs warning relay
9 blue alternator
10 violet/black temp relay
12 violet/white choke indicator
14 white/blue bulb monitor
21 blue/green turn signal cancel/flasher relay
24 gray/blue backlights
also, 22 and 23 might be switched? in the thread someone said the brown was the speed sensor?
1 Red/White Clock Power (other stuff too)
2 Yellow/White Gear Position Switch
3 Yellow/Black Gear Position Switch
4 Yellow/Blue Gear Position Switch
5 Black/Green Starter Switch(Clutch in or gear=0)
6 Green/Black Power
7 White Low fuel lamp
8 Green/Yellow ABS Warning Relay
9 Blue Alternator
10 Violet/black Temp relay
11 Brown/Green Oil light
12 Violet/White Choke indicator
13 Brown Ground
14 White/Blue Bulb monitor
15 White High beam
16 Black/Blue Tachometer
17 Blue/Black Right turn indicator
18 Brown Ground
19 Blue/Red Left turn inicator
20
21 Blue/Green Turn signal cancel on flasher relay
22 Yellow Speed Sensor
23 Brown Ground
24 Gray/Blue Backlights
