Author Topic: Hit a bump, lose the gear?  (Read 5792 times)
Offline Lucas
« on: July 18, 2013, 07:28:53 PM »
I have a strange gremlin that I cant replicate over and over. Sometimes when I hit a bump kinda hard, the bike seems to go out of gear and I have to futz with it to get it back in. This is usually accompanied by the Gear indicator being blank.
Seems if I upshift things go back, but if I downshift its grindy (like trying to go into 1st too soon if you know what I mean).
It's only happened a few times though, and really has to be a pretty good bump. At first I thought my foot was just jamming the shifter, but would that cause the indicator to go out??
 :falldown:
Offline CRASH
Re: Hit a bump, lose the gear?
« Reply #1 on: July 18, 2013, 08:04:33 PM »
Make sure your shifter is adjusted correctly and that you are going ALL THE WAY into gear on your shifts.
- CRASH -
Offline Lucas
« Reply #2 on: July 18, 2013, 08:35:23 PM »
I'll assume adjustment is covered in my Clymers, but how do I even know I am going all the way into gear?
« Reply #3 on: July 18, 2013, 10:08:49 PM »
Quote
Yep, it sure can. I've done it many times.
I haven't had it come out of gear, but I have had "lazy" shifts and end up between gears and the gear indicator display goes blank.
Offline Lucas
« Reply #4 on: July 19, 2013, 11:56:04 AM »
Quote
I'm not sure it was completely out of gear since I don't know the bike all that well yet. It's was weird and wouldn't seem to downshift. But good to know that it happens.
Offline CRASH
« Reply #5 on: July 19, 2013, 08:28:58 PM »
Normally you can feel he difference between a clean shift and a lazy shift.  Just pay closer attention when you shift and make sure it is a complete shift each time and see if you keep having issues.  I had to screw with my shift lever - cut, grind, reposition, JB weld ... it was quite a mod to move the shifter so that a human size foot could use it.  I think that BMW uses giants for seeing if you can flat foot at a stoplight, and a midget to see if the riding ergos are right.
- CRASH -
« Reply #6 on: July 19, 2013, 09:54:51 PM »
My regular riding boots don't give me any troubles with up-shifts.
From time to time if I make a quick run to the store or something I may grab my tennis shoes, or lighter boots that aren't as thick on the top side of the toe. That's when I may have the occasional lazy shift. Yea, I know I need to be more persuasive and give it a sure, and solid shift. If I really think about it in the front of my head, it doesn't happen.
Offline Lucas
« Reply #7 on: July 21, 2013, 02:49:27 PM »
I don't really have a problem with lazy shifts in general. My Honda has an occasional slip from 2nd to Neutral that was solved by shifting up with authority and holding for a split second, which seems to be the sort of way that the K likes to be shifted on a normal basis.
So I tried hitting a few solid bumps, but removed my foot from the shifter and haven't had any lazy shifts, so I'm guessing it really was just my foot tapping the lever.
