Author Topic: K100 starter problem  (Read 5430 times)
Offline tiddy305
« on: May 27, 2013, 07:43:01 AM »
Hi All,
 Im back on the road again after several years off!! No better way than to buy a K100 LT in England and ride it all the way to the south of Spain, 1442 miles over 3 days! I bought a 1991 model with only 43392 miles on it, ex Police bike, so fully serviced. The last service was 48 miles ago, but 6 years ago. Real good tidy bike.
 All went well apart from the last day when after refilling, the starter wouldn't engage, nothing at all. I rocked the bike in gear and it started on the switch, after that no problems for the rest of the day. At home the next day the bike wouldn't start again on the switch, over the last 5 days it has either;
1) Made no noise at all when the switch is pressed,
2) Made a current sounding noise with clicks heard beneath the petrol tank and lefthandside panel,
3) Once started on the switch after rocking the bike in gear,
4) Always starts if you put it in 3rd/4th and bump start it down the road, still wont start on the starter though,
  I dont have any other electrical problems, lights, horn etc, all work fine.
 Any suggestions please, I have read possible causes, and am thinking it may need a starter motor or an overhaul,
 Regards,
 Tiddy
Re: K100 starter problem
« Reply #1 on: May 27, 2013, 09:23:02 AM »
I'd suggest when you get home, if you aren't already, read here: http://www.ibmwr.org/ktech/starter-cleaning/starter-cleaning.shtml
and here: http://skylands.ibmwr.org/tom/tech/starter.html
Sounds like you need to clean and service the starter.
Offline artcollinsjr
« Reply #2 on: May 29, 2013, 09:09:07 PM »
if its whirring, ie turning with no engagement, you can clean the starter sprag clutch by draining the oil and replacing it with high detergent motor oil (used by diesel vehicles). I did this after a no start condition, and after a few hundred miles, I changed back to full syn oil and I have not had a no start since. It will also clean your sight glass!
Offline tiddy305
« Reply #3 on: May 30, 2013, 04:07:14 PM »
Hi everyone,
 Thanks for the posts. I intend to have the starter taken out and cleaned. However I decided to give it a tap as a last resort effort, and lo and behold it now starts on the button! Guess the thing just got stuck.
 Regards,
 Tiddy
Offline rocket23
  • bmw ride on!
« Reply #4 on: May 30, 2013, 04:30:25 PM »
Yeah, the brushes were askew.......not to say that it wont repeat itself.........cuz it will eventually.
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out, and screaming,'WOO HOO! What a ride!'"
Offline noppo
« Reply #5 on: June 02, 2013, 08:30:27 AM »
i can vouch for this.  i did the job when it warmed up (diagnosed in mid-winter), and all has been well ever since.  Dealer wanted a pretty penny for the job, but you can easily do it yourself.  Save yourself the money, and put it towards your next spline lube or something else.
  • Tokyo, Japan
  • 1992 K1
:bmwsmile Noppo - Tokyo, Japan
11 months here, 1 month in USA (TN)
