Author Topic: On road trip, I broke down!..  (Read 40505 times)
TajMan
Re: On road trip, I broke down!..
« Reply #50 on: July 04, 2013, 12:45:02 PM »
I have another used combo switch I need to install,
I assume I need to take apart the front faring to get to the connector behind headlight or abouts?
I just haven't taken any of this apart before yet
Offline K75RT Keith
« Reply #51 on: July 04, 2013, 02:12:55 PM »
No, if it's an RT you won't need to pull off the fairing.  You may be able sneak by if after you lift the tank and disconnect the old switch, you tie a string to the end and pull it back to the switch body.  Tie the string to the replacement switch and GENTLY pull the new cable into the same route.  You may need to give it a helping hand depending how you attach the string.
1990 K75RT
« Reply #52 on: July 04, 2013, 02:13:52 PM »
Actually you will find the connector under the front of the fuel tank, with a whole bunch of other wires and connectors.....
