Author Topic: grub screw and shifter etc/////  (Read 7716 times)
jeffhestand
« on: May 09, 2013, 11:16:12 PM »
got to the inside of the the tranny and the grub screw is very obivous that it is loose. I feel with some long allens i can loc tite and tighten without a  lot of disassembly.... i am concerned though about where the shift lever should be set before i tighten it down. Is there a detent or a flat this screw if tightening into or should i just loctite, tighten and hang it back together? I have a feeling many owners have done this before??? thanks again !  :yes
jeffhestand
Re: grub screw and shifter etc/////
« Reply #1 on: May 10, 2013, 10:36:40 AM »
is there a write up on this site or any other site that anyone knows of for the grub screw procedure and getting the foot shifter in the right spot before retightening and loctiteing.... etc.. thanks!!!  :bmwsmile
« Reply #2 on: May 10, 2013, 10:42:52 AM »
Have you seen this?
jeffhestand
« Reply #3 on: May 10, 2013, 02:23:28 PM »
no i havent. Watched a little of it already and this is EXACTLY what i was looking for .... THANK YOU  :clap:  I will watch it at length with a cup of coffee in the Am ,. Thanks Jeff
cy7878
« Reply #4 on: May 10, 2013, 03:56:21 PM »
great, just when I thought I was done.....
