Author Topic: nasty fuel leak  (Read 3997 times)
grant71
nasty fuel leak
« on: February 08, 2013, 08:55:05 AM »
Hi. a few days ago while  on a ride ( K100 )  i experienced  a nasty petrol leak. petrol poured  down the  left  side  near  the  foot rest over the  exhaust pipes. you can imagine  i got the fright of my life. switched off stat. got hold of a friend  to have a look. behind  what i understand to be the throttle  bodies we  espied  a  black fuel pipe running horizontally towards the rear. between 3 and 4 a 90 degree turn downwards into a receptacle male pipe which i took to be the press regul. am i right? the  fuel pipe had come adrift at this junction. my friend  coaxed the  pipe back on and i got home safely . question i must ask is how  does one repair this ? ie. the procedure sequence and replace new fuel pipes. the pipe has been crimped on. i will remove this and  replace  with a quality clamp. i need help please. never done any mechanical work on  this 86 K100 RS. IM IN Capetown
Offline mjydrafter
Re: nasty fuel leak
« Reply #1 on: February 08, 2013, 01:37:40 PM »
Yeah, it sounds like you should replace the fuel lines and clamps (if they're the crimped type).  Get real injection clamps as the cheap worm-type are not the best for injection systems.
Check down the list in here (workshop) I think there are a couple of fuel line threads. (as far as length, and type).
1986 BMW K75c
Re: nasty fuel leak
« Reply #2 on: February 08, 2013, 01:59:41 PM »
You'll need three feet of either 5/16 or 8mm fuel line.  Make sure it's fuel line that's pressure rated for fuel injected systems.
13mm hose clamps - BMW part 13311460928
grant71
Re: nasty fuel leak
« Reply #3 on: February 08, 2013, 02:57:52 PM »
thanks mjydrafter and  duck. i found info im looking for in the Lieberry.
