Author Topic: Cooling fan  (Read 8554 times)
Hadyn
Cooling fan
« on: January 22, 2013, 06:45:08 PM »
does the fan run all the time or turn on only when riding for a long time i dont know if mine is working
Re: Cooling fan
« Reply #1 on: January 22, 2013, 07:18:57 PM »
The fan should start when the engine reaches 103oC.
Not unusal that the fan is stucked, caused by to less use..........and high pressure washing equipment.
Inge K.
Re: Cooling fan
« Reply #2 on: January 22, 2013, 07:48:47 PM »
There is an easy way to jumper the wires in the junction box under the tank.  That will tell you if your fan runs or not.  I think those instructions are in the Lieberry area here.  Do a search and see if you can find it. Or maybe someone will link if for you.
Re: Cooling fan
« Reply #3 on: January 22, 2013, 08:09:47 PM »
Remove relay, and jump terminal 15 and A2.
Inge K.
Hadyn
Re: Cooling fan
« Reply #4 on: January 23, 2013, 08:54:08 AM »
thanks will try on day off
Marky Boy OZ
Re: Cooling fan
« Reply #5 on: October 10, 2014, 05:16:28 AM »
Hi guys,
I'm new to K1100 - my cooling fan is not working and is sticky.
The bike is pulled down - do I go straight out and get a new motor, or, is it possible to pull the motor down and clean it up.
Thanks
Re: Cooling fan
« Reply #6 on: October 10, 2014, 02:14:09 PM »
The most common problem with the fan motors is melted brush holders caused by seized or sticky  axle/motor.
Re: Cooling fan
« Reply #7 on: October 10, 2014, 02:33:38 PM »
So since I don't think they even make rebuild kits for these crappy motors, your best bet is to buy a new fan motor from beemerboneyard.com or euromotoelectrics.com and swap the old with the new -- probably around $80. Search this forum for install details. Or go to the dealer and pay about $250 for a new fan assembly -- but while you're at the dealer don't drop the soap!
Re: Cooling fan
« Reply #8 on: October 10, 2014, 03:07:43 PM »
It would probably be cheaper to visit a Bosch dealer/workshop, if such a thing exist down under.
Fan motor: Bosch 0 130 007 027.
Offline bocutter Ed
Re: Cooling fan
« Reply #9 on: October 13, 2014, 08:06:42 AM »
My K75 cooling fan was in the same condition when I got the bike year & a half ago. 'Sticky' was turning the fan by hand and the fan was spinning on a seized shaft.
It is 'possible' to remove the front cap from the fan motor, knock the armature from the cap, and polish the shaft. I lubed with 65% Moly. Don't know that I'd do it again.
  • Toronto, Canada
Offline Kyle10
Re: Cooling fan
« Reply #10 on: October 13, 2014, 03:00:51 PM »
Radiator fan replaced with Spal, possible fuel pump issue
http://www.motobrick.com/index.php?topic=2617.msg29578;topicseen#msg29578
This has worked great for me. Tons better than the OEM setup.
1985 K100rt
1983 Honda VF750F
The other 2% made it home.
Marky Boy OZ
Re: Cooling fan
« Reply #11 on: October 18, 2014, 05:13:50 AM »
Well boys and girls, I tried my best to make a set of bushes (from and old set of starter motor bushes - with a Dremel)
I used a 2 part epoxy to remark the housings for the bushes.........
It all went back together well - but, I could not get continuity between the two terminals, I suspect I did not make a sure enough connection between the brushs and the terminals .  . . .
K Bike cooling system brushes
Oh well - I tried,,,,,,
I got a 12V 3100RPM electric motor with very similar dimensions off the net today for $31 AU delivered from Hong Kong.
I will post the results.....
