Author Topic: My very long term K 120rs Project  (Read 39946 times)
Offline pfls
Re: My very long term K 120rs Project Begins
« Reply #25 on: September 25, 2013, 08:18:31 PM »
On my K100/K1200RS engine swap I used a 95 K1100 fuel injection harness, and a K1200RS Motronic computer. The plug on the harness and computer are physically the same, but the pin in/outs are in different locations. I can't remember if the wire colors used are the same for both models.You would need a wiring diagram from both models to make sure you get everything right. There are also map coding wires used in the K1200RS that need to be correct for the bike to run right. I wanted to retain the looks of the standard K100, so I kept it's wiring harness and instruments. On K100's and K1100's, the fuel injection harness is separate from, and plugged into, the main chassis harness. On a K1200, it is all in one. There was an article on my project in the BMWMOA magazine a few years back. I'll see if I can pull it off of my old laptop and send it to you if you want.
90 K1200 standard
04 MV Agusta Brutale 750
Offline Freelancer
« Reply #26 on: October 04, 2013, 05:05:46 AM »
Thanks Pfls,
Or do you prefer to be called Paul?
Either way, thank you for the info and sources to see your lovely bad-ass sleeper.
As to my projekt, will be in a holding pattern until Nov-Dec but will continue the discussion here and my performance mods thread.
Gotta go,
Freelancer
1991 K100RS
Offline pfls
« Reply #27 on: October 04, 2013, 06:34:05 PM »
Let me know if I can help when you start up again. Paul
90 K1200 standard
Offline Freelancer
« Reply #28 on: May 11, 2015, 02:28:24 AM »
Hey guys,
I know it has been a while but I want to let everyone know that this build is still in the works. It just got sidelined when I hit a deer a while back while on my 91 k100rs.
  I had collected more than a full set of spare body pieces and was down to just needing the motor, frame, forks & wire harness when I took the side trip to the "petting zoo".
  I will create another thread to cover the extent of damage and subsequent repairs to my "girl". Just letting you guys know that the build is still on though much delayed.
Later,
Freelancer
1991 K100RS
Offline Hicks1109
« Reply #29 on: June 24, 2017, 08:10:20 PM »
Hi interesting reading. sent you a message. Cheers steve
  • Wirral uk
  • K1100rs K1200rs r1100s k100 gsxr1100g. Slabside
Offline jenkinskg
« Reply #30 on: June 03, 2018, 01:45:18 AM »
Talking ecu, what about a k1200 ecu with o2 sensor on the k75
easy to deal with, or untunable?
