Author Topic: LED to check the oil level  (Read 8825 times)
« on: December 26, 2012, 11:34:30 PM »
The oil sight glass on K1100RS bikes is buried in the fairing and you usually need to dig out a flashlight just to check the oil level.  I originally made one of these for my K1100RS several years ago.  Its amber and uses the older LED technology of the time.  I decided to make one using a better LED for my K75 that I recently put a K1100RS fairing on.  While I was at it I made two of them so I can upgrade the old one on my K1100RS.
You can see the old one in this picture:
My LED of choice for this little project is a white 12V Ba9s 1W SMD LED scored from a Chicom on Fleabay.
Step 1: Cut a strip of aluminum – angled at one end – you’ll see why later.
Step 2: Drill two holes in it. One Ľ” hole for mounting the bracket on an M6 bolt. Another 3/8” hole for mounting the LED.
Step 3: Put a right angle bend in the aluminum strip.
Step 4: Put the LED in the 3/8” hole and epoxy the front housing of it to the aluminum strip.
Step 5: Flip it over and put a bead of solder around the base of the bulb to ensure good conductivity between the aluminum strip and the LED.  When bolted to the engine this grounds the base of the LED.
Step 6: Solder a wire to the positive contact of the LED.
Step 7: Wrap the base of the bulb with electrical tape and fill it with epoxy to insulate the positive terminal/exposed wire.  Once the epoxy’s cured and the tape’s been removed it will look something like this:
Step 8: Mount the bracket on the oil sump cap head bolt above and behind the oil sight glass. (Now you can see why the mounting end needs to be angled.) Then bend/tweak the aluminum strip to fine tune the aiming of the LED.
Step 9: Put 12V+ switched power to the wire.  On my K75, I modified my ABS switch to be a three position switch with a momentary position for the ABS functionality and a non-momentary position that triggers a small relay to power the oil sight LED.  Alternately, since it’s an LED with very low power consumption that lasts “forever,” you could just tap it into the parking light circuit or whatever have it on whenever the bike is on.
Voila! No more need to dig out a flashlight to check the oil level. It’s not exactly pretty but that doesn’t matter since it’s hidden inside the belly pan.
Offline CRASH
Re: LED to check the oil level
« Reply #1 on: December 27, 2012, 12:09:33 PM »
That is a great mod.  :2thumbup:
I see more LEDs in my future.  :hehehe
- CRASH -
Offline Opus
  • 1988 K100 LT
« Reply #2 on: December 27, 2012, 01:24:02 PM »
Love LEDs...
Bright with low power usage.
Can be mounted in strips to make your ride stand out on the road.
Smart Setup Duck. Will be doing this as soon as it gets warm enough to be outside working again.
Thanks for your ideas.......
Happy New Year!!!!
Toney
Offline orforester
« Reply #3 on: December 27, 2012, 10:30:08 PM »
Duck, I just did a simliar thing with mine, only I glued a 6 Led strip to the belly pan holder, (metal part).  Dilled a hole in the dash panel.  Right side.  Then added $3.00 Rat Shack switch to the dash.  The switch lights up when power is on.  Like yours it really tosses a lot of light in the darkness!  No more flashlight.  LED's are great, the strips are wonderful for all kinds of lighting.  The one I used was Amazon, Motorcycle led light strip, actually in hard plastic.  I soldered the wire from an old lamp (heavier wire) and covered the whole thing in that wire covering stuff, like on trailers.
My wife says I have gone over the edge.  Replaced interior lights on her new car with LED's, lots brighter.
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
« Reply #4 on: December 27, 2012, 11:14:16 PM »
Just wait until you see my LED projects I have in the works for 2013.....
CharlesPotter
« Reply #5 on: July 23, 2013, 01:56:41 AM »
The oil sight glass on K1100RS bikes is buried in the fairing and you usually need to dig out a flashlight just to check the oil level.  I originally made one of these for my K1100RS several years ago.  Its amber and uses the older led lighting technology of the time.  I decided to make one using a better LED for my K75 that I recently put a K1100RS fairing on.  While I was at it I made two of them so I can upgrade the old one on my K1100RS.
[/u]
Thanks for sharing your experience and this wonderful thought? I will try to check oil level with led and hope it works.. Thanks again
