Author Topic: What are these parts?  (Read 7938 times)
Offline Pagman
« on: October 14, 2012, 08:37:13 PM »
When I first got my K, I cleaned out the crap from under the seat pan that the p.o. left behind. Can anybody identify these before I throw them out?
'86 K100rs- naked
'97 Vulcan VN800
'02 Harley Dyna Superglide
Queens, NY
Offline wildbill
Re: What are these parts?
« Reply #1 on: October 14, 2012, 10:07:47 PM »
The piece on the far right looks like the seat holder-upper (prop). the white thing to the left of that is a mystery, to the left of that appears to be a master cylinder piston, the two brackets don't look familiar to me...
  • Central Ohio
Offline Pagman
« Reply #2 on: October 14, 2012, 10:49:21 PM »
Thanks for clearing that up for me. Regarding those two pieces on the left, only one was attached on the bike until i removed it. I met a person who was knowledgeable on bmws and even he didn't know what this part was for. He thought maybe it could have been a part to a side car, but wasn't sure. The pic shows where it was attached...
'86 K100rs- naked
'97 Vulcan VN800
Queens, NY
Offline Duc750
« Reply #3 on: October 15, 2012, 12:58:27 AM »
The white thing is the adapoter from a co2 inflation kit. Could the bits on the left have been used to mount the side panels - compensating for a broken lug or something?
2001 K1100LTIC not even run it at 52K
1994 Duc 907ie
1998 R850R
1987 Duc 750 Paso
Rick G
« Reply #4 on: October 15, 2012, 02:53:10 AM »
I was cleaning my workbench about 3 weeks ago and found one of those white things and I knew it was BMW but it has been bugging me since as to what it is and now I know.
The flat thingies that go where the circle is may be something to do with rear crash bars as that is where they attach.
I bet Inge will know if they are BMW or add ons.
Offline Inge K.
« Reply #5 on: October 15, 2012, 04:32:46 AM »
Sorry, no idea about those brackets...but I do agree about the conclusion on the other parts.
BTW. Your injection ECU is mounted the wrong way around, now the rubber feets don`t absorb
vibrations.....and I would guess that multi connector isn`t that fond of being so close to the
coolant expansion tank (if the bike much used in slow moving traffic......)
Inge K.
  • Norway
Offline Pagman
« Reply #6 on: October 15, 2012, 10:42:48 PM »
Inge K.
You must have sharp eyes. I thought it was on the way it should be, although I did notice a little awkwardness with the ecu housing. A p.o. issue. I attached some clearer pics. Can you point out exactly what you're referring to? A pic maybe?
'86 K100rs- naked
'97 Vulcan VN800
Queens, NY
Rick G
« Reply #7 on: October 15, 2012, 11:12:30 PM »
The plug with all the pins should go to the left side of the bike. As you put it into the compartment you will see 2 slots on the bottom of the plastic where the 2 rubber grommets fit and there should be a pin to go through the other end and hold the right side in place.
Offline argent brick
« Reply #8 on: October 16, 2012, 12:19:12 AM »
.... the two brackets don't look familiar to me...
I used to own a boxer that had a power outlet back by the seat. It was mounted with a bracket that looked like those. Not logical to have a mount there without an outlet though. Just a thought.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
