Author Topic: Cleaning Parts/tools/grime + Random Questions  (Read 12473 times)
Offline iiXioM
« on: October 02, 2012, 03:00:31 PM »
Good day all! I have to say this forum is turning into my K-Bike bible!
So here's my question:
Just picked up an 87 K75s literally 24 hours ago. What can i use to clean up dirt/grime/mud/25 yrs of gunk and crap off the bike? The tools are all greasy, and would just like to clean it up overall. What can i use that won't cause anything to rust, flake, or destroy the current state of paint?
Does anyone have a link to show how to change the transmission/final drive oil? I seem to have a hard time doing so.
Last but not least...are there any fixes to the gauges to get the mileage tracker thing working again other than buying a new cluster?
Thanks!
  • New Orleans, LA
  • 1985 BMW K100RT
Re: Cleaning Parts/tools/grime + Random Question
« Reply #1 on: October 02, 2012, 03:06:59 PM »
Wheel cleaner on the wheels.
Gunk on the trans and swing arm.
Cleaner wax on paint.
Pledge on vinyl seats.
PlastX on windscreens.
Trans oil change: General maintenance tips.
Offline iiXioM
« Reply #2 on: October 02, 2012, 03:19:29 PM »
Really that simple to wash the crud off? Wow...i feel dumb. lol.
As far as the Trans oil change...I see the cut outs but can't tell where the drain/fill plugs are. Or maybe i'm not looking at it correctly. Is it really just drain oil fluid and refill with new? Nothing special?
  • New Orleans, LA
  • 1985 BMW K100RT
Re: Cleaning Parts/tools/grime + Random Questions
« Reply #3 on: October 02, 2012, 07:06:33 PM »
You can buy the odometer unit for about $100 from BMW -- part number     62 11 2 305 175
Installation is fussy but not difficult if you're patient and take time to see how things are put together.
This repair was one of the first things I did to my '85 K100.
Fifth Horseman
« Reply #4 on: October 03, 2012, 03:46:12 AM »
Odometer repair viability depends on the cause of failure. Can be caused by:
1.  Poor connections - clean  with Detoxit
2.  Broken gears - replacements can be got, but may be easier to find new unit
3.  Broken solder joint - simple to fix if you can solder, the hard part is finding the connection causing the problem.  My bike had an intermittent odo, eventually traced to a broken wire to the stepper motor.
Offline iiXioM
« Reply #5 on: October 08, 2012, 04:53:13 PM »
I have a feeling this bike has broken gears in the cluster. Any idea where i can find a new set? The bike has been fairly well maintained so i dont think its bad connections or anything, though i will check that out nonetheless.
  • New Orleans, LA
  • 1985 BMW K100RT
Offline Opus
  • 1988 K100 LT
« Reply #6 on: October 08, 2012, 07:37:13 PM »
Lookup Overseas Speedometer.
They can replace the gears for you.
But it will cost you .
Toney
Offline Pagman
« Reply #7 on: October 08, 2012, 11:09:23 PM »
Purple Power and Oomph degreasers worked well for me. That will get rid of the majority of grease and oil off your bike's surface. Also, grade 00 steal wool will work well for your wheels and even rusty areas without scratching them up. The stains in your metal might have to be buffed out.
'86 K100rs- naked
'97 Vulcan VN800
'02 Harley Dyna Superglide
Queens, NY
Offline iiXioM
« Reply #8 on: October 12, 2012, 09:52:24 PM »
Purple Power and Oomph degreasers worked well for me. That will get rid of the majority of grease and oil of your bike's surface. Also, grade 00 steal wool will work well for your wheels and even rusty areas without scratching them up. The stains in your metal might have to be buffed out.
I just got some Purple Power today. I'm hoping it works out well.
I just got around to working on this bike finally.
Flushed Coolant - The junk in there was all muddy/brownish colored. ran a whole gallon of distilled water to clean it up a bit
Oil/filter changed - Also junk. it was pitch black.
Going to be changing out the spark plugs in the morning. one thing i cant find anywhere....is there any specific gap measurement i need to set them to? I got the Bosch X5DC's.
Thanks!
  • New Orleans, LA
  • 1985 BMW K100RT
« Reply #9 on: October 12, 2012, 10:11:04 PM »
You can find that in the Clymer Manual :)
Mine says:
Recommended 0.6-0.7 mm (0.024-0.028 inches)
Maximum Gap Limit 0.9 mm (0.036 inches)
Offline iiXioM
« Reply #10 on: October 12, 2012, 10:19:22 PM »
Mine says:
I could have sworn i read through the spark plug section of the book and i saw it said max limit was 0.9 mm, but there wasn't anything about the recommended measurements. Thanks alot, i must be already going blind at 26. lol
  • New Orleans, LA
  • 1985 BMW K100RT
« Reply #11 on: October 12, 2012, 11:27:07 PM »
Don't forget to flush the brake fluid.
Offline iiXioM
« Reply #12 on: October 13, 2012, 12:15:37 AM »
Yeah, most definitely. Is there anything special in doing so? Can i completely drain out the brake fluid, and then refill, making sure no bubbles are in it? I'm under the impression that completely draining the fluid empty causes some type of issue with the lines. I read that a few years back somewhere. Perhaps im misinformed, and thats exactly how to do it.
  • New Orleans, LA
  • 1985 BMW K100RT
« Reply #13 on: October 13, 2012, 09:42:36 AM »
ABS or non-ABS?
« Reply #14 on: October 13, 2012, 11:17:08 AM »
Don't remove the fluid from the lines first. Remove the fluid from the master cylinder and add new to it. Start bleeding at either the ABS modulator or caliper and keep adding fresh fluid to the M/C making sure not to let it run dry or suck air down into the lines. Do this until you get fresh fluid at the calipers.  Do both calipers. If you started at the modulator (unnecessary IMHO) move down to the calipers after fresh fluid appears and continue.
Offline iiXioM
« Reply #15 on: October 13, 2012, 12:20:38 PM »
ABS or non-ABS?
Non-ABS
Ah thats it...don't let air get in the lines, thats what i remember reading some time ago. Awesome, i'll definitely try this out, sounds fairly simple. Thanks alot guys, great help!
  • New Orleans, LA
  • 1985 BMW K100RT
« Reply #17 on: October 13, 2012, 01:39:52 PM »
Turn the handlebars(and if needed rotate the throttle perch) to make sure the little hole in the master cylinder is the high point.
