Author Topic: That time of year again for chilly fingers or heated grips  (Read 4572 times)
Offline tsbt
« on: September 21, 2012, 04:52:51 PM »
Looking at Symtec with Heat-troller, does the alternator on the K100RS support it? or should I upgrade my alt to a 50? I suppose if I want CATZ and a Xenon bulb I should upgrade the alt anyway. Did I just answer my own question...:hmm:
92 K100RS 4V
75 KE125
Re: That time of year again for chilly fingers or heated grips
« Reply #1 on: September 21, 2012, 05:05:29 PM »
$4 - variable heated grips mounted in dash pad:
Variable heated grips - Version 2.0
Motorandy123
« Reply #3 on: September 23, 2012, 08:17:36 AM »
I found an ad that says they draw 3 amps on high (heated grips). That's only 36 watts so should be OK by themselves.
When you add the other stuff you might be pushing it (literally!).
If you throw a 50 watt HID in the headlight you wouldn't need the 50 amper...
« Reply #4 on: September 23, 2012, 10:42:24 AM »
The CATZ XLOs are 70W each.
