Author Topic: Tricking out your K Motor. (Just for Fun!)  (Read 18169 times)
Offline Opus
  • 1988 K100 LT
« on: July 30, 2012, 10:47:22 PM »
Okay here is the setup!
You have a extra K-Bike motor and the funds to trick it out to the 10's. I'm not talking BLING here now, but to really max out the power.
The only limit is that it has to be able to bolt to your frame. You can beef up the frame and other parts of the bike, but must retain the Org. look.
Oh and it must be a real and avalable upgrade, so no warp engines folks.
Let the BS begain!!!!! :loco:
Toney
Rick G
Re: Tricking out your K Motor. (Just for Fun!)
« Reply #1 on: July 30, 2012, 11:57:44 PM »
K 75 Pistons, K1100 throttle bodies remove the rev limiter of just go buy a K1200s and you get 40hp with no problems.
« Reply #2 on: July 31, 2012, 12:22:20 AM »
I recently hooked up with a local bike wrench who claimed he got a K75 from 74hp on a dyno to 93hp by decking the head.
Offline argent brick
« Reply #3 on: July 31, 2012, 12:58:43 PM »
What is "Decking the head"?
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
« Reply #4 on: July 31, 2012, 01:10:14 PM »
Machining down the face of the cylinder head. This creates a smaller compression chamber - thereby increasing your compression ratio.
« Reply #5 on: July 31, 2012, 01:33:52 PM »
« Reply #6 on: July 31, 2012, 02:05:47 PM »
Sounds like what we called a "milled head".
Lynn
1976 R60/6 RIP
BuffaloRider
« Reply #7 on: July 31, 2012, 11:18:34 PM »
I've also heard this called "alignment bored" and knew a guy who did it on a Gold Wing with tremendous results. Excellent power returns but also a really smooth running motor. I can see the advantage in doing a job like this on a motor like the Brick's.
« Reply #8 on: July 31, 2012, 11:23:24 PM »
Agreed. My K75 with a paralever needs a little more grunt coming out of turns.  I'm keeping my eye open for a low mile motor at a decent price to experiment with this.
BuffaloRider
« Reply #9 on: July 31, 2012, 11:32:13 PM »
The paralever conversion sounds interesting. How difficult was it and what all did you need to swap out?
If you are tearing down to do an alignment bore and head re-decking you may as well finish the job off right.
« Reply #10 on: August 01, 2012, 01:02:30 AM »
Converting a monolever K75 or K100 to a paralever final drive
BuffaloRider
« Reply #11 on: August 01, 2012, 01:24:46 AM »
So the entire operation is largely just replacing parts with similar units from later models?
« Reply #12 on: August 01, 2012, 05:23:59 AM »
Yup.
« Reply #13 on: August 02, 2012, 10:13:26 PM »
One guy put a turbo on the K75. Got a bunch more power and torque.
Only has 55 hp stock at the wheel, so the 74 is at the crank.
A low pressure turbo is fairly tame on the motor. The only way to get significantly more power is to add forced induction, as the limiting factor is the air that goes past the valve. There is not a whole lot of power past the rev limiter on these bikes.
RBR turbos did some work on these when they were new. They pushed a K100 past 200 mph.
WoahGold
« Reply #14 on: August 12, 2012, 10:48:41 PM »
I saw one of those K100 turbos. I don't think I'd ever do it but it was interesting none the less.
I think having the block milled would be a great for the bike. I had the block from a 1947 Farmall B I was restoring sent away to be milled, reground, etc. and it made a huge difference.
Offline CrashBar
« Reply #15 on: August 14, 2012, 04:23:18 PM »
What was different in the K1200 RS motor that it was rated at 130HP vs the K1100 at 100?
Thats a 30% bump on a 9% displacement increase.
Someone (duck?) did a swap, I wonder if it really felt like 30% more.
As I recall the K1200 LT was rated at the same HP but more torque.
  • Boston MA
  • 1993 K1100 LT
....to trade in these wings on some wheels...
1993 K1100 LT (143,000 miles and counting)
1973 CB350F / 1978 CB550K / 1973 TR5T
« Reply #16 on: August 14, 2012, 09:04:57 PM »
Quote
And the K12LT weighs about 150# more
« Reply #17 on: August 17, 2012, 04:18:18 PM »
The K1100 Motronic is "de-tuned" to what at the time was a 100hp voluntary horsepower limit on the Euro bike market.
