Author Topic: Tail light problem K75S 1990  (Read 4361 times)
kjel-man
« on: July 22, 2012, 05:45:29 AM »
Hello!
I have a strange problem with the taillight on my 1990 K75S (ABS). When I put the ignition switch to parking light, both the backlight and front bulb light up as it should. When I put the ignition switch in the start position, both bulbs turn off.
Does anyone have an idea what this error might be?
Kjell
Re: Tail light problem K75S 1990
« Reply #1 on: July 22, 2012, 06:42:23 AM »
Welcome Kjell!
If your cluster light shows when ignition on, the problem is in the ignition switch.
If the cluster light doesn`t show, the problem is in the light on/p/off switch.
Ignition switch dismantling.
Inge K.
kjel-man
« Reply #2 on: July 22, 2012, 09:51:47 AM »
Thank you Inge K!
The ignition switch is brand new. The cluster light do not shows, so it must be the light on/p/off switch.
Kjell
« Reply #3 on: July 22, 2012, 12:58:04 PM »
RHS switch assy dismantling.
The problem could also be in the switch assy connector under the tank,
the grey/blue wire is the park/tail/cluster feed, measure at both sides of the connector.
Inge K.
kjel-man
« Reply #4 on: August 02, 2012, 07:40:40 AM »
Problem fixed!
Thank you Inge K
Kjell
