Author Topic: Sudden death  (Read 32766 times)
Offline Zorman
Re: Broken Pin?
« Reply #25 on: June 25, 2012, 07:57:25 PM »
Quote from: kennybobby
It looks like you have a broken male pin in that connector?
NO, it's just a bad picture. All 4 pins are there.
Offline Zorman
Re: Sudden death
« Reply #26 on: June 25, 2012, 08:03:43 PM »
So Inge, what would you do to fix the flaky connector on his 86? Or does he have to replace the fuel pump?
Sometimes pictures wiewed on the computer could be quite different from as seen with your own eyes in the real world, but those male connector pins looks far from clean to me........and if the female is in the same condition.................search DeOxit.
The fuel pump is a separate unit, the connector is combined with the level sensor as one unit.
Inge K.
I think I used Permatex Anti-sieze lube on the connectors before, which contains aluminum powder so it actually conducts electricity. I'll check out DeOxit, thanks. So as it stands now, aftermarket connector won't work and I have to find a way to clean the pins and the socket & check the combo switch.
'85 K100
Re: Sudden death
« Reply #27 on: June 25, 2012, 08:13:38 PM »
Quote
That may be the problem right there. That's not for electrical connections but for keeping bolts and nuts from seizing.
Offline Zorman
Re: Sudden death
« Reply #28 on: June 25, 2012, 08:35:00 PM »
Quote
In my experience, it works pretty well for connectors. The petroleum base prevents oxidation while the aluminum powder provides conductivity. I do need to de ox the pins and squeeze the female pins into a smaller circle though.
'85 K100
Re: Sudden death
« Reply #29 on: June 25, 2012, 08:40:44 PM »
+1.  De ox the females also, and be shure they squeese really tight around the male ones. :drool: :loopy:
Inge K.
