Author Topic: Clutch Tool  (Read 7120 times)
Offline jimmyd
  • 1994 K1100 RS
Clutch Tool
« on: June 07, 2012, 01:02:50 AM »
Hey K People
I have a 1994 K 1100 RS. Long project trying to get at the SPRAG.
I stripped out two bolt heads on the outer pressure plate. What a project to get them out, but I did get them out, after using a dremel tool to file down the bolt head and finally using an extraction bit.
Now I am at the clutch.
Anyone have the tool that holds the clutch in place so that it won't turn while I remove the 30mm bolt that holds the clutch in place?
I would be glad to buy it or rent it from someone.
1994 K 1100RS
Re: Clutch Tool
« Reply #1 on: June 07, 2012, 01:34:42 AM »
A Block of wood will work wonders. Just stick it in, and pull the nut
Re: Clutch Tool
« Reply #2 on: June 07, 2012, 04:54:37 AM »
Here is the dimensions to the BMW tool # 11 2 800, so you can make your own.
Inge K.
Re: Clutch Tool
« Reply #3 on: June 07, 2012, 07:48:01 AM »
+1. That's what I used.
Offline Photog
Re: Clutch Tool
« Reply #4 on: June 07, 2012, 09:01:08 AM »
+2
  • NNE
  • K75-S
Offline jimmyd
  • 1994 K1100 RS
Re: Clutch Tool
« Reply #5 on: June 11, 2012, 09:03:48 AM »
I don't recall seeing (didn't actually look) any line up marks on my clutch plate (like the reds ones in this picture), nor did I put any on there.
Am I headed for trouble putting this puppy back together?
 Is there some kind of timing routine that I will need to do?
1994 K 1100RS
bricklayer
Re: Clutch Tool
« Reply #6 on: June 11, 2012, 10:49:49 PM »
The red marks I don't believe are factory, there is/were however white marks on the carrier, pressure plate and outer cover. I read something in the Clymer manual about spacing these marks apart ( under the clutch section) as they are weighted and could cause a vibration if improperly aligned. I don't know how much of a difference it will actually make.
Offline Photog
Re: Clutch Tool
« Reply #7 on: June 12, 2012, 07:12:07 AM »
I added the red marks so that I didn't have to rely on the wimpy white ones from the factory.
  • NNE
  • K75-S
