Author Topic: Could a paralever trans be used with a monolever swing arm?  (Read 3870 times)
bricklayer
During a spline lube I found that I could saw wood with the input shaft & friction disk splines. Need a trans swap. Looking for options.
thanks.
Rick G
Re: Could a paralever trans be used with a monolever swing arm?
« Reply #1 on: May 28, 2012, 08:35:13 PM »
Yes the only difference is the tags the paralever attaches to, they just are not used.
« Reply #2 on: May 29, 2012, 06:16:36 PM »
Aside form the aforementioned tangs for the front of the paralever strut, the only differences between transmissions are:
a) 1990 and later (including mono and parlever) the metal of the trans input splines is supposedly harder than the earlier splines.
b) When putting a para trans on a K75 the fifth gear ratio goes from 1.67 to a slightly taller 1.61.(same for all 4 cyl bikes)  About a 3% difference - probably something most people wouldn't notice.
Aside from that it's bolt on and go.....
