Author Topic: Bosch Headlight  (Read 12700 times)
Minus Juan
Bosch Headlight
« on: May 10, 2012, 02:46:32 PM »
Just got an 88 K-75 S and noticed that the low beam headlight is not quite as bright as I would have hoped for. Is this a typical issue. When I flipped to high beam it seemed to be proper but normal low beam just seemed a little dull.
If this is a typical issue, is there a aftermarket headlamp that throws a better group of lumens?
Thanks in advance,
minus
Re: Bosch Headlight
« Reply #1 on: May 10, 2012, 02:53:24 PM »
Stoop down a little lower.  K bikes have a pretty sharp beam cutoff on the low beam.
How to make your headlight brighter: Headlight Relays
combatmmuter
Re: Bosch Headlight
« Reply #2 on: May 15, 2012, 02:01:08 AM »
i enjoy the extra output of an HID, H-4 bulb in the K1100RS. more light, sharp cutoff still visible and no extra lamps hanging around.
got mine here:      http://www.ddmtuning.com/Products/DDM-35W-55W-Single-HiLo-Motorcycle-HID-Kit] [url]http://www.ddmtuning.com/Products/DDM-35W-55W-Single-HiLo-Motorcycle-HID-Kit[/url]
 and less costly than one of those incandescent high watt things that blow out the handlebar switches.
you know how i know.
Rick G
Re: Bosch Headlight
« Reply #3 on: May 15, 2012, 02:36:24 AM »
Put the relays in I think you will like the extra light you get and regardless of what bulb you have the handlebar switches will give out sooner than later too
Minus Juan
Re: Bosch Headlight
« Reply #4 on: June 06, 2012, 07:51:19 AM »
Combat,
You wouldn't know if that would work in my 75s would you? If it would, does it require adding some beefier wireing and/or a relay?
Thanks to all for the comments and help, it is really great to have this much expertise available to tap.
Re: Bosch Headlight
« Reply #5 on: June 06, 2012, 08:06:41 AM »
Combat,
Combat's post looks like he's most likely a spammer.  Be VERY wary of anybody who has only one post and is plugging a product.
HIDs work best with headlight reflectors/lenses that are specifically designed for HID - which K bike headlights aren't.  HID "upgrades" in non-HID headlights usually emit light scatter - which is why they're illegal and can get you a ticket.
Offline DRxBMW
Re: Bosch Headlight
« Reply #6 on: June 06, 2012, 10:15:36 AM »
If you use a dual relay wiring harness for the OEM headlight,30% brighter light from the get go. I run a super PIAA 140/75W H4 in my K 75 whip, most excellent lumen output.
PLUS ! your switchgear will NEVER DIE from excessive voltage bleed off.
If I were converting to HID, these Trailtech lights below would be my first choice. 50% less than than the EXPENSIVE Touratech model, almost a direct clone. Internal ballast, Paul has them on his K 100 RS,impressive. He runs one driving,one fog there that bright. Wired/tapped into his high beam, read easy to dip for oncoming traffic.
http://trailtech.net/single_hid_sc4.html
aux lighting is a debatable subject, go here for more info.
http://faq.f650.com/FAQs/AftermarketLightsFAQ.htm
FWIW, Pep Boys Auto has driving lights priced at $35.00 each. If your on a budget,equal to the $300.00 PIAA's. They work well, enough said.
LED's is the future of lighting, NOT for me yet but the technology is getting better as time progresses.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Re: Bosch Headlight
« Reply #7 on: June 06, 2012, 10:34:29 AM »
What's the part number for your PIAA 140W bulb?
Offline DRxBMW
Re: Bosch Headlight
« Reply #8 on: June 06, 2012, 10:58:03 AM »
opps, wrong wattage factor quoted.   Plus, there NOT PIAA branded, my bad, had the extra one stashed in a PIAA box. Seem to hold up OK, reasonable in cost, been 9 months since R&R.
CEC H4 90/130 Watt (High Output Low Beam and High Beam) Clear Replacement Bulbs (2 bulbs) Part # CECH413090W
Item# CECH413090W
http://www.highperformancebulbs.com/h4bulbs.html
http://www.highperformancebulbs.com/headlight-and-foglight-bulbs.html
FWIW, the blue tint is strictly to "imitate" HID cosmetic image factor. In reality terms, it does absolutely nothing for brightness other than looking cool.
If I were really a cool cat K, I be running a custom bricKhead yellow HL to stand out in the crowd,  :bmwsmile :bmwsmile
Gary
Williamsport,Pa
2005 F 650 GS
Re: Bosch Headlight
« Reply #9 on: June 06, 2012, 04:52:09 PM »
I like the Selective Yellow bulbs. Really make you stand out, and also lower glare for other drivers.
Offline CRASH
Re: Bosch Headlight
« Reply #10 on: June 06, 2012, 04:58:17 PM »
Combat,
The DDM unit should work in your bike and you should not have to do any wiring upgrades, but if what I am hearing I understand, you may want to regardless (relays and such). (full disclosure, I have had mine on my K1200GT for about 2 years and love them but do have a beefier alternator)  I have DDM in high and low, the high takes a little time to warm up, but if you flip it off and then on for on coming cars, it is fine. I usual suggest folks try out the low beam and see what they think, with the low and a standard high beam, you should be very happy with the light.
- CRASH -
Re: Bosch Headlight
« Reply #11 on: June 06, 2012, 05:50:53 PM »
That's not exactly true.  The blue tint makes Xenon bulbs whiter, not bluer.  I run the xenon X4s with a blue tinted bulb in all of my bikes and the light has virtually no blue tint to it at all and looks nothing like HID.
