Author Topic: Alternative Fuel Filter  (Read 29364 times)
Offline DRxBMW
« on: March 28, 2012, 08:50:17 PM »
alternative fuel filter list ______________.
The Mahle Knecht listed below is the genuine BMW one...if you can find it...
Autozone ff424?
Triumph T1240850
AC GF61
BMW - 16 14 2 325 859
Fleetguard FF149
Fram G2
KNECHT MAHLE KL145 OEM (Amazon)
Motocraft FG-2
Napa Gold 3032
Deutsch model FF424
Purolator - F20011
Wix 33032
FWIW, I'm a fan of the NAPA 3032 filter,$5.00 Vs $36.00 for OEM BMW.
Tip: reuse your original hose, the hose supplied is NOT gas resistant.
From the list at IBMWR.org, with a few annotations from me (wmax351).
Fram (Mustang) gas filter for K75 gas filter
Date: Wed, 10 Jun 1998 16:13:12 -0700 (PDT)
> have a rider who needs the substitute #'s for a fuel filter on a K.
> Some mustang years will sub. right???
The Fram filter for my 1996 Ford Mustang GT, 4.6L, is resting nicely inside the tank of my 1993 K75s. Same fuel pressure rating, 7.9mm rather than 8mm fittings, so you have to tighten the hose clamps a little farther. The body is larger, so it takes finesse to put it into place, but it fits.
Fram G3802A was $8.99 at Kragen auto parts, about 2,000 miles ago.
note from motobrick johnny... i have used the napa 3032 for years... 3 bucks... replace them every 10,000 miles... have never had fuel system failure... yeeeeehaaaaaaa...
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Re: alternative fuel filter list
« Reply #1 on: March 28, 2012, 08:52:44 PM »
Good stuff. I'll add it to the Card Catalog.
Offline Uffda
« Reply #2 on: March 29, 2012, 07:48:11 PM »
For someone new to the bike wrenching experience, I will say the info on the Napa 3032 was worth the price of admission to motobrick.com.  For the $5 cost and experienced rider recommendations (Thank you DR), I keep one on hand and change the filter on my bike every 10K.  Seems pretty cheap insurance to me.
  • New England
  • 1995 K75RT
Robert
Re: Alternative Fuel Filter
« Reply #3 on: December 09, 2015, 05:11:35 AM »
 Mann fuel filter MWK 44 available in Australia.Supposed to be OEM as well as Mahle.
Regards Martin
« Reply #4 on: May 05, 2016, 11:23:58 PM »
...Fram G2...
So the Fram G2 is okay for K's fuel injection pressure?
« Reply #5 on: May 05, 2016, 11:54:00 PM »
I always used fuel filters with steel housings, may be subjective but I figured they'd be stronger.
« Reply #6 on: October 15, 2016, 05:29:42 PM »
For Oz Brickers Ryco Z200 and Z200 copies can be had for between $9.00 to $20.00 Au Ebay. Standard Ryco Z200 $14.88 Au Ryco Z200MAS marine filter conical on one end but should fit $17.45 Au at Supercheap. AC Delco ACF4 fuel filter can be had $7.00 Ebay click and collect Woolworths.
« Reply #7 on: October 15, 2016, 08:20:08 PM »
Based on their oil filters, I will not use a Fram filter for anything.
Offline Madbmr82
« Reply #8 on: October 28, 2016, 08:51:51 PM »
could anyone tell me if the plastic purolator listed is safe to have submerged in the tank? a little worried about that.
note: pepboys has it for $3.24 (promocode: 35pep)
  • East Los Angeles
  • 1985 K100 RT
« Reply #9 on: October 28, 2016, 09:07:21 PM »
Personally unless they are guaranteed for fuel injection pressures I would stick to the metal ones.
Offline SmilingRide
« Reply #10 on: November 04, 2016, 08:14:09 PM »
Hi there, I am confused and cautious.
I saw the recommendation @ the MAHLE KL145 and went to Amazon.
There is a tool they offer online to check if its the right part for your bike.
It said that it was not a fit for my 95 K75...thoughts from the experienced?
Thanks
  • Arlington, VA, USA
  • 1995 K75
« Reply #11 on: November 04, 2016, 08:29:36 PM »
I like to support the businesses that support my riding choice.
Beemerboneyard.com has the Mann filter for $17.95  http://www.beemerboneyard.com/16142325859.html
Offline F14CRAZY
« Reply #12 on: November 05, 2016, 09:06:59 AM »
I've been using the Napa 3032. In stock locally and cheap
  • Grand Rapids, MI
  • '87 K75C
« Reply #13 on: November 05, 2016, 09:24:22 AM »
+1 on the NAPA Gold 3032.  Wish I knew what the filters that cost $12 to $20 more are giving me that the $5 NAPA doesn't.  My bricks seem to be happy with the NAPA filter.
Offline Elipten
« Reply #14 on: November 05, 2016, 09:29:47 AM »
More profit to the importer, BMW and other crooks
  • San Antonio, TX
  • 1990 K75RT
« Reply #15 on: November 05, 2016, 09:32:47 AM »
That's what I suspected.
« Reply #16 on: November 05, 2016, 04:30:12 PM »
Thanks
The Amazon tool is not programmed to recognise this vehicle-part combination so it reverts to the safe option - telling you it is not supported.  That's a CYA for Amazon. The Mahle does indeed fit and function in the K-bike.  You should not trust the artificial intelligence of Amazon Inc.; believe the hundreds of K-bike owners who have successfully used this filter in their bikes.
Offline SmilingRide
« Reply #17 on: November 05, 2016, 11:09:30 PM »
Thanks @rbm- that is helpful. The Mahle was my first pick, but since tomorrow is my day off and I didn't order it I think I'll drop by NAPA & pick up the recommended fuel filter there.
  • 1995 K75
Offline woodgeek
« Reply #18 on: February 06, 2018, 12:54:13 PM »
Quote from: DRxBMW link=topic=2057.msg10836#msg1
[b
KNECHT MAHLE KL145[/b] OEM (Amazon)
Rockauto has the MAHLE KLEVITE (KNECHT) for 11.67.
  • Henderson, NV
  • 1985 K100RT
