Author Topic: HELP NEEDED PLEASE  (Read 3999 times)
monty8563
HELP NEEDED PLEASE
« on: March 02, 2012, 03:51:35 PM »
Hi all,
 have been trying to adjust my handle bars on ,my k1100rs, started with the l/h/s and found the small alen bolt backed it off a bit and turned the cluster with no problem, tryed to do the same on the r/h/s master cyclinder side and I CANNOT FIND THE BOLT please can someone tell me how to do this side or find the fittings thankyou in advance monty
Re: HELP NEEDED PLEASE
« Reply #1 on: March 02, 2012, 04:11:28 PM »
Remove the combo switch.  Be careful undoing that Phillips screw.  Use a good screwdriver so you don't strip the head.
Also, don't overtighten the bolts that clamp the perches to the bars.
monty8563
« Reply #2 on: March 03, 2012, 07:12:39 PM »
Thanks for the info, have now done the job, you were right about the phillips screw had to drill it out as someone before had rounded it off
