1995 k75S ABS
The good: I got it to start, all lights work, the fan clicks on, shifts smoothly & brakes work. Alternator charges nicely. Propane test ( no change in rpm’s at 1.2k ) coils test 1.5 primary 10 secondary
The bad: Can’t get it to idle nice…Tank leaks, abs not working, will remove.Forks pitted & leaking
Balanced throttle bodies… balanced well at all rpms. (# 3 was out more than 1&2)
The bike will run ok with brass screws 1&2 all the way in…not sure if that is relevant.
UPDATE! The bike is running better after an Italian tune up…good enough for now
Question;
Forks are Showa and are pitted badly…Option #1 is sand them smooth # 2 Can I swap them out entirely? Or are the triple clamps too big? Please see attached photos. Can/ should I just sand out the blems?
Also has anyone had success replacing seat cover?
