Author Topic: Spark plug collective wisdom  (Read 109 times)
Offline Eayars
« on: November 07, 2026, 01:51:27 PM »
Here are plugs 1, 2, and 3, respectively, from a 1990 K75S with 52,500 miles. Mileage on the plugs is unknown, since I got the bike at 52,300; but based on the records I have available the bike was not ridden more than 100 miles in the previous 10 years and the unknown owner prior to that was meticulous.
Any collective wisdom on the state of these? #2 and #3 look rich to me; and the bike seems a bit thirsty although I’ve also been fixing gas leaks so I’m not positive about that. #1 looks about right, though. Do I need to start thinking about injectors?
Edit: Turn your computer over if the picture bothers you. I’m uncertain why it’s upside down… but you get the picture.
  • Chico CA
  • 1990 K75S
Re: Spark plug collective wisdom
« Reply #1 on: November 07, 2026, 02:10:51 PM »
What are the spark plugs' model numbers, and what do the electrode gaps measure?
Offline TriSpark
« Reply #2 on: November 07, 2026, 02:55:34 PM »
Looks like #3 may not be getting any gas, or hardly any. The plugs are D7EA NGK's, right? That's what is in my K75s.
  • Chattanooga TN
  • Red 1987 K75s and Blue 1997 F650
No Brick Left Behind !
Offline daveson
« Reply #3 on: November 07, 2026, 04:55:27 PM »
Spark plug one is the best, spark plug three is the worst, and spark plug two is the middlest.
There is a z shaped hose entering the plenum chamber near cylinder three, if this hose is cracked, excessive unmetered air could be entering the system, and so the impact would be worst on cylinder three. This might be the cause of the problem.
  • Victoria, Australia
Offline Edward
« Reply #4 on: November 07, 2026, 04:58:12 PM »
clean your injectors. Just send them out to Mr. Injector for a fast turn around of refreshed units. Price is great so no worries about that. If your K sat for that long just do it. Personally, I use iridium plugs. Starting base with clean injectors is just smart.
  • USA
  • K75s 1987 Original owner
Offline Edward
« Reply #5 on: November 07, 2026, 05:00:33 PM »
balance your air intake (throttle body) AFTER installing clean injectors. Reset TPS.
  • USA
Offline Eayars
« Reply #6 on: November 07, 2026, 05:16:35 PM »
The plugs are NGK D7EA.
Bear in mind that the picture insists on posting upside down, so the plugs are 3-2-1 left-right.
3 (blackest) 0.026
2 (middlest) 0.027
1 (lightest) 0.026
  • Chico CA
  • 1990 K75S
Offline Eayars
« Reply #7 on: November 07, 2026, 05:19:21 PM »
Since the picture posted upside down (although maybe it’s showing correctly in Australia?) the order left-right on your screen (with the motorcycle on the ceiling) is 3-2-1. Same answer?
  • Chico CA
  • 1990 K75S
Offline Edward
« Reply #8 on: November 07, 2026, 05:21:17 PM »
From the moon: plugs are fine.
  • USA
« Reply #9 on: November 07, 2026, 05:39:27 PM »
Have you been able to do an Italian tuneup or two on that Brick in the 200 miles you've owned it, Eayars? If not, do one for as many miles as you can, then take a look at the plugs. You can brush off the carbon right now.
Offline daveson
« Reply #10 on: November 07, 2026, 06:04:34 PM »
Yup, 3,2,1. I turned it upside down and assumed 1,2,3.
Offline Eayars
« Reply #11 on: November 07, 2026, 09:15:48 PM »
I’m unfamiliar with the term “Italian Tuneup”. Can you translate to Scots? Is that the equivalent of ‘WFO’ in Suthun’?
Here’s what I’ve done so far:
- Rerouted return hose in fuel tank so it doesn’t just pump gas out the tank vent line
- Tested pressure regulator (it’s ok) and replaced external fuel lines so they stopped pouring gasoline onto the top of the engine
- Replaced front crankshaft seal
- Replaced all fluids and filters
- New tires (BT46, love ’em)
- Replaced front wheel bearings
- Starboard-side bodywork/paint (the bike came with a drop-discount)
- Replaced starboard lighting
- Replaced starboard luggage
- Replaced an assortment of bulbs
- Removed aftermarket brake-flasher circuit that had apparently been installed by drunken lemurs, repaired wiring
- Installed a phone mount/charger
- Adjusted rear brake switch so it actually turned on the brake lamp
- Ridden 200 miles and filled the tank four times.
… Yeah, that last one is annoying. 22mpg on the last tank. This is a vast improvement over the 8mpg I got while the fuel pump and leaky regulator hose and misguided in-tank sealant application were conspiring to happily pump $6/gallon California gas out in a smelly flammable trail behind me everywhere I went, but I was really hoping for closer to 40mpg.
New injectors are on order… At this rate, the $3,000 F800ST I passed on as ‘too expensive’ in favor of this K75S is looking like a damn good deal, but I’m hopeful that I’m running out of things to fix.
  • Chico CA
  • 1990 K75S
Offline Edward
« Reply #12 on: November 08, 2026, 12:13:18 AM »
Don't fret over the plugs; it's no big deal. Once the injectors are installed, the throttle bodies are balanced, and the TPS is reset, you should have a more even burn and better gas mileage. There really wasn't any need to buy new injectors instead of having the existing ones cleaned or refurbished, but many people do the same thing, regardless of the bike's brand. When you had the tank off, did you clean the screen at the bottom of the fuel pump? Tip: Installing quick-disconnects on the fuel lines helps tremendously when removing and reinstalling the tank.
  • USA
Offline Eayars
« Reply #13 on: November 08, 2026, 12:30:54 AM »
It’s not the plugs I’m fretting about, it’s 22mpg and I think the plugs are indicative of the problem. There is also a gas smell on warm restarts (and it acts flooded) so I think probably the injectors are not closing entirely and the FI rail is depressurizing through injectors 2/3. I’m pretty sure I know what’s going on, but this is my first “modern” BMW (haha) so asking experts… Thanks for the help!
Oh, and quick-disconnects. Brilliant, thanks. Recommend a brand/source?
  • Chico CA
  • 1990 K75S
Offline Edward
« Reply #14 on: November 08, 2026, 01:01:56 AM »
I'll take a look at my records and snap a photo of the setup when I'm more awake.
  • USA
Offline Edward
« Reply #15 on: November 08, 2026, 10:13:20 AM »
installed early 2023 without any problems to date. Smartest modification other than suspension and full floater conversion.
beemerboneyard.com
New CPC Chrome Plated      cart-special-2         1  115.95
Brass Fuel Line Quick Disconnect Set - Oilheads & K-Bikes
                                           Subtotal  115.95
                                           Shipping    9.95
                                                Tax    0.00
                                              Total  125.90
  • USA
« Reply #16 on: November 08, 2026, 08:58:51 PM »
These are Boneyard's.
