Author Topic: Rear brake question  (Read 760 times)
Offline Lbxpdx
Rear brake question
« on: July 10, 2026, 03:08:44 PM »
I was checking my pad thickness for the first time and realized I could not get the front pin out to check the rear pad thickness as it hits the rear shock.  Does the caliper need to be removed to change the pads or I’m doing something wrong?  Clunker stated to just remove pins.
92 K75RT abs.
  • Portland
  • 1994 K75S, 1992 K75RT, 1972 R60/5 & 1977 R100S
Re: Rear brake question
« Reply #1 on: July 12, 2026, 05:31:42 PM »
If the pin cannot be pulled from the assembly, remove the two caliper mounting bolts then slide the caliper along the disc until the pin clears.
