Author Topic: k75 code/ECU scanner?  (Read 1078 times)
Offline mrt6644
« on: July 07, 2026, 01:27:04 PM »
I did a few searches and nothing.
Is there such thing as a OBD type scanner for the K75?
  • US
  • K75, R1200RTP, R1250GS
Re: k75 code/ECU scanner?
« Reply #1 on: July 07, 2026, 03:10:30 PM »
Many have sought; none have found.
« Reply #2 on: July 07, 2026, 03:46:12 PM »
I have 2 pdf files related specifically to the Jetronic fuel systems of the k75.
Lets see if they attach to this post.
« Reply #3 on: July 07, 2026, 04:23:33 PM »
The tools in the links Scott has supplied: The top photo is the main unit's control panel; the middle photo is the harness plug connection and the bottom image contains drawings from the diagnostic and testing manual of the main unit and the plugs used for the fuel injection control and the ignition control unit.
If you're diligent, you could eventually find all the components. Right now on eBay, a main unit is offered for sale without the plugs.
Offline mrt6644
« Reply #4 on: July 10, 2026, 09:48:24 PM »
Thanks!!
  • US
