Author Topic: K75 T with Timing Chain Rattle - pre diagnoses?  (Read 204 times)
Offline bluebossa
  • K75 and R65 Owner
« on: June 30, 2026, 07:14:16 AM »
Hey again folks...
Yesterday I bought a fairly rare K75 T - at least in the UK, not many were sold, the UK weather I think putting most people towards the RTs
Anyway its a Red, 1994 T with ABS... now while I'm not a fan of ABS on K Bikes, too much complexity and added weight, I do like a Naked K Bike... I'm especially fond of the K75 as you might know, this is my 5th now.
While I'm waiting for it to be couriered up to me - could you help with what I might go after...
Here's the description from the Seller as to front end timing noise...
"Some weeks ago, the engine developed a loud rattle at low revs. I was concerned enough to pay a mechanic to check the bike over. He advised that there was a problem with the cam chain and said that it would cost £700 to repair. The bike starts well. It may or may not be rideable in its present state. I am disinclined to risk riding it."
Now I've got a spare Engine - taken from my 50k K75 C on the floor and I'm thinking
- timing cover off - on both new bike and donor Engine
- compare chains and chain tensioners
- replace everything guide wise and spring wise from the 50k Engine
Happy to post pics, videos when it arrives - maybe later this week.. but I've never done a timing chain so any tips, what to look for, anything else the noise could be coming from?
Meanwhile here's a pic of the 48k K75 T - planning to save this one rather than strip for parts... as I've also started stripping K75s - took an RT apart last week and started an eBay shop called "Flyingbrickparts" in the UK
Thanks in advance - would appreciate your wisdom on what to look for first?
  • UK
  • K75C
Current Bikes: K75 (C) in the UK (1986), R45 (1981)
Former Bikes:  K75RT, K75S, R850R, K1100RS, Dnepr MT10-36, R1200GS, K100, R100T, R100RT.
BMW R45 and K75 Blog
Re: K75 T with Timing Chain Rattle - pre diagnoses?
« Reply #1 on: June 30, 2026, 07:41:19 AM »
It would be helpful for you to make a video containing the noise with all its permutations during idling and moderate revving, post the video on YouTube as public, and then post the link here. In my opinion, it's too early to focus on the timing assembly although it's a possibility. When somebody indicates a loud rattle, the alternator rubber dampers are my first consideration and relatively easy to rule out. Faulty fuel injectors would be next.
Offline bluebossa
  • K75 and R65 Owner
« Reply #2 on: June 30, 2026, 08:27:12 AM »
Interesting, thanks Laitch, I love the fact that you don't just jump and assume, a fault of mine... I'll happily do that on arrival and post on YouTube..
Alternator Dampers and Injectors - Intrigued...
The Timing assembly was the guess from a Mechanic the seller Employed... so I'm with you...
  • UK
  • K75C
Offline TriSpark
« Reply #3 on: June 30, 2026, 09:04:06 AM »
The cam chain rattle diagnosis sounds like a guess from a mechanic who hasn't much experience of K bikes, and that's not unusual as they don't see them on the work bench as often as they used to. 48K miles.....my K75 has 120K and no trace of any cam chain noise at all. When I lived in London I had a plain K100 with 80K on it, and no cam chain noise on that either.
One thing I've learned here is to always follow Laitch's advice before tearing into the engine. Let us know how you get on.
  • Chattanooga TN
  • Red 1987 K75s and Blue 1997 F650
Offline bluebossa
  • K75 and R65 Owner
« Reply #4 on: June 30, 2026, 10:38:39 AM »
Laitch is a legend, I always listen to him, hence my post - Laitch has saved me hours of faffing around over the years, thanks TriSpark... video on arrival with good sound.
Agree re Mechanic though it must be some noise from somewhere... does seem low mileage though for Cam chain as you say!
  • UK
  • K75C
Offline bluebossa
  • K75 and R65 Owner
« Reply #5 on: July 03, 2026, 07:37:37 AM »
OK @Laitch as requested... it arrived on my drive this morning UK time...
Its got the high RT bars - but its a T - Naked... nice old thing, one of the later ones.... 1994 with ABS (which I hate)
Here's that Video and I do think your remote diagnoses may well be spot on - so I 'll dive in and let you know...
Certainly not going to open the front yet... !
  • UK
  • K75C
Offline bluebossa
  • K75 and R65 Owner
« Reply #6 on: July 03, 2026, 09:11:31 AM »
Yep... any tips on how to remove the drive on the end of the alternator, needs that and new monkey nuts...
THANK YOU LAITCH - AGAIN SAVING ME Hours!
I've got a spare but the drive is the same - replacements en route...
  • UK
  • K75C
« Reply #7 on: July 03, 2026, 09:48:34 AM »
That's a useful video. I recommend anybody with a mysterious noise post something like that for group diagnosis.
I used a strap wrench to anchor that cup for removal. Use Liquid Wrench, Kroll or PB Blaster on the nut and screw. After spraying, tap the nut and screw joint a few times—without deforming either—then let them sit for fifteen minutes or so before disassembly. This is my usual procedure on fasteners that likely haven't been touched for years. Regardless of what you choose to do, they should release each other without putting you through a dying strain on the end of the wrench. If they do, regroup, heat up the fasteners with a heat gun, apply the penetrant until you're smoked out of the room, have a coffee then try again.
It looks like you've got things under control. Wipe the dampers with silicone grease so they'll stick into position. Align the arrow so the paddles will index correctly into the damper joint spaces.
Offline bluebossa
  • K75 and R65 Owner
« Reply #8 on: July 03, 2026, 11:13:15 AM »
Thanks Laitch - Sorted, big lever and it relented... 22mm socket
Its a lovely Bike - weird that Naked T with RT bars, but maybe they switched to that for the later models... My C bars are lower...
  • UK
  • K75C
Offline TriSpark
« Reply #9 on: July 04, 2026, 10:19:22 AM »
Good video and photos - thanks for sharing those, I learned something new about Bricks from that. I viewed the video, and it's clear the knocking noise is at the back of the engine, nowhere near the cam chain. With the rubber dampers being 40 years old, it's no surprise they have crumbled and failed. Better check mine.......I had the starter motor seize up on my K75 due to old age, so I hope my alternator is not going to go next.
Much better than tearing the engine apart only to find the cam chain is just fine, right?
You've got a nice looking K75 there.
  • Chattanooga TN
« Reply #10 on: July 04, 2026, 11:50:05 AM »
The higher bar is the original equipment—T meaning touring. From what i've read it was a dealer-installed limited edition. The same bar is OEM on the RT and the Standard. My Standard had it plus an aftermarket National full windscreen. After 10K miles, I removed RT bar and windscreen to install a C-bar. I also sold the Corbin Canyon seat with its backrest at that time. I returned to the OEM bench but the custom padding within it is honeycombed, its profile allows me to shift my butt fore and aft according to riding conditions and it's comfortable on hours--long rides unlike my experience with the OEM.
After 5K more miles I removed the C-bar to install a sidecar bar. The sidecar bar is as low as an S-bar but is wider and has less pull-back. After decades of bicycling thousands of miles with dropbars on touring bikes and straight bars on mountain bikes, the sidecar bar gave me a comfortable and familiar riding posture while lessening wind drag on my body and allowing my butt and thighs instead of my back to absorb any excess road shock. The Brick is still as black as in the top photo; it had a case of the blues the day it was photoed.
Offline bluebossa
  • K75 and R65 Owner
« Reply #11 on: Today at 07:25:05 AM »
Thanks Tri Spark 100% - glad the video helped someone... I've fitted the new Alternator nuts and Cup now and yes, I've seen 2 other Alternators start to chew the fins... rubber donughts are fairly cheap so a really good idea to change them before you get to that stage... this K75 is a 1994 with under 50k so that's a nudge to do it if your bike is similar?
Yep - glad I didn't have to go into the front and look at the Cam chain... but all good, its lovely and quiet again!
I'm in a dilemma now about which to keep as I have a 1986 K75C which I've put a new 8k Engine into which is running great... really pleased to sort this for a low cost and a few hours labour, though getting everything out to get the Alternator out is a mini project...
Thanks re Bike - I do like them in Red... its a nice original and well serviced machine...
Post Fix Video as promised for Sound comparison!
  • UK
  • K75C
Offline bluebossa
  • K75 and R65 Owner
« Reply #12 on: Today at 07:34:58 AM »
Thanks Laitch, yes interesting... I'm in two minds about the Bars... while they are more upright I like the C bars, though they do put more pressure on the hands... also wider and less traffic friendly I think...
Figuring out which to sell now, can't have 2 even though I'd love too - garage space is a premium.
1986 K75C - with an 8k Engine - think you read that story - drivetrain feels new
1994 K75T - with 48k and ABS - both Red, though different Reds
Side by side picture taken this morning as I returned the screen to the T - its a BMW one... both lovely triples...
Which would you keep? Which would you sell and why?
  • UK
  • K75C
Offline bluebossa
  • K75 and R65 Owner
Centre Stands
« Reply #13 on: Today at 07:41:36 AM »
Here's another little puzzle I'd like help with - Centre Stands..
Were there different versions of the centre stand RT / S / C / T?
this might explain why is my 1986 K75C is now so hard to get on its stand...
My C might now have a centre stand from an RT, though I thought it was from an S, as the drivetrain I put on was an S - though the orginal Bike it came off was an RT, I know all very confusing- are RT stands taller? The C now sits 4/5 inches off the ground at the back, it does have the 17 inch wheel now, whereas originally it had the 18 inch Drum brake wheel, I initially thought it was just that, but several near hernias later, I'm not so sure.
Pics for comparison - 1st two are 1994 K75T with original stand, see height - second 2 is 1986 K75C with what I think is an RT stand, see how high it sits
I just assumed that centre stands were all the same!
I think I still have the C stand - the 1994 is a dream to put on its centre stand, while the 86 now gives me a near hernia everytime!
I tried jacking the Bike today, but didn't find a way to get it high enough without losing all stability to try and swop them over - I have an Engine Jack flat plate type - any tips on how to change the Stands without taking the whole back end off?
  • UK
  • K75C
« Reply #14 on: Today at 01:43:56 PM »
Whenever I want to know if one particular part is the same on different models, I use a parts fiche. If the numbers are the same, the parts are the same.
According to Max BMW's parts fiche, the Standard, the S, the T, the RS and the RT 2V models all have the same stands and brackets. Measuring them would confirm that. However, sometimes a 4V side stand has been installed when the original hollow tube 2V stands have been deformed or broken by the effects of internal rust. Yours is not 4V stand. An 18" wheel definitely makes the lift easier because the mass you're moving is already raised by a half-inch and the angle of the lift has been modified favorably. A tire with an 80 aspect ratio requires somewhat more effort because the mass is lower than when carried by a tire with a 90 ratio and the angle of the lift also has been altered.
Lubing the stand pivot is of utmost importance to lessen effort. Dried grease—or no grease—makes lifting exponentially more difficult. I lube the stand whenever I sense more effort in a lift. It could be necessary to disassemble the stand to inspect and clean its pivot pin and bushing.
If you had years of lifting that Brick onto a stand when it had an 18'' rear wheel, your body's muscle memory hasn't adapted to the difference yet but it will. Verify the front wheel is aligned during the lift. Misalignment will increase friction resulting in more effort.
