As I already over-covered in my "hey it's the new guy" post, I have a 1987 K75S that I bought new, rode regularly until around 1994 before putting into storage. It's sat untouched in my garage ever since...until now.
I'm now a retired empty-nester and my wife and I will be moving before long so I guess it's time to get this thing back on it's wheels again. I had already removed the tank and all the bodywork years ago to fix some frame rust and they'll be needing a respray, which is unfortunate as apparently the Lava Red paint color is a pretty rare find that was only offered in 1987. Regardless, it's time to set up shop:
Getting Started.jpg (100.29 kB . 768x576 - viewed 4473 times)The body parts will be the last priority, obviously I have to get the mechanicals squared away first. Somehow a few of the fiberglass parts got cracked so that will all need repair before painting. They'll stay out of the way for now.
Body Parts.jpg (76 kB . 768x576 - viewed 4567 times)The first priority is getting the engine running, fortunately I sprayed the cylinders down with oil prior to hibernation so the engine spins freely. I played it safe and changed the oil and filter, good thing because the old stuff was thick as gear oil. I also drained the coolant and replaced it with a gallon of distilled water for now. I already knew the fuel pump was bad, so I ordered a new kit with hoses and filter. While waiting for that I did an inventory of what else was in need of attention. Both master cylinders were shot and the rear one was seized, so I started with that. The screws securing the MC to the foot peg mount were stuck solid, I removed the entire bracket but I couldn't even impact them loose. I feared this would be a harbinger of things to come but pressed on. I decided to disassemble the cylinder in-situ, and big surprise that wasn't happening either.
20241209_161641.jpg (59.34 kB . 768x576 - viewed 4806 times)I soaked it with penetrant for days and finally got the guts to free up enough to hammer out with a small punch. Yuck...
Unseized.jpg (66.27 kB . 768x576 - viewed 4689 times)It's the dreaded 13mm Magura unit so replacement will be a challenge. Motobrick to the rescue as I found several posts here with "alternative" options using generic master cylinders. I'll give the original cylinder a good inspection to see if it's even salvageable, if not it's fabrication time. Fortunately the caliper itself, although leaking, came right apart and just looks like it needs new seals. Well that's a little hope at least but forget that for now because THE FUEL PUMP IS HERE!!!
20241216_205456.jpg (55.76 kB . 768x576 - viewed 4565 times)It went together easily enough, more to follow. Thanks for reading.
