Author Topic: What Foam Grips Do You Like  (Read 4222 times)
Offline PitchlerBrick
« on: December 06, 2024, 02:21:07 PM »
Whose hand grips do you like? My throttle-side grip is splitting down the long side; time to replace! Thank you.
  • Garaged & Covered, Central Texas
  • '93 K75S w/Pitchler Fairing, Tri-Spoke, Corbin, 50 Amp Alt., OsideTiger Injectors, Catz XLO Lamps w/Auto Switch, Flip-A-Lever Cruise, Hyper-Lite rear brake flasher, OEM Luggage Rack
Offline natalena
Re: What Foam Grips Do You Like
« Reply #1 on: December 10, 2024, 02:40:33 PM »
Grip Puppies are on the brick and HD, both are the "big dog" size which allows a more relaxed open grip. The KLR has Oxford heated grips since it's a year round workhorse.
  • MST
« Reply #2 on: December 10, 2024, 09:50:32 PM »
Hey, thanks!
Offline natalena
« Reply #3 on: December 11, 2024, 10:36:18 AM »
Just checked the grips, and the Big Paws on the HD fit directly onto the throttle tube. The K75S, the foam grips go over the stock rubber grips. I've got chopstick fingers, and it's much more comfortable. Cheers
  • MST
Tags: handle bars
