Author Topic: K1100 early 1993 wiring with motogadget m unit  (Read 57913 times)
Offline BCK2WRK
Re: K1100 early 1993 wiring with motogadget m unit
« Reply #25 on: January 22, 2025, 04:31:48 AM »
Happy to report brick started on a first try with the new wiring. Thank you everyone for your help. I have one more question,  very small one in a grand skim of things, but I have an issue with the kill switch lol.
I am using a switch from cbr1000rr and no matter how I wire it, the kill switch works in reverse.   My guess is I have to reverse polarity inside the switch. Diagram attached.
Glad to hear it worked for you.
I am currently working on the same model of k1100 as yours, with the same ecu  can you share your final wiring diagram here pleāse?
  • Hong Kong
  • K1100RS 1993
Offline Kaos
  • Vlad the Extractor
« Reply #26 on: January 22, 2025, 05:42:32 AM »
Hey bud, the first few comments of this post/topic contain several k1100/4v wiring diagrams.
Engine wiring for this specific ecu are mentioned in these diagrams.
Happy wiring
  • Basically Everywhere
Offline BCK2WRK
« Reply #27 on: January 22, 2025, 06:09:22 AM »
Hi Kaos, thanks for the quick reply
I do have the oem wiring diagram for both 93- and 94+ k1100, my k1100 is a 93 model equiped with ignition output stage and co potentiometer.
 However, I encountered problem when installing the m-unit blue and would like to see if Lucas could share his finial wiring diagram for me to cross check my work.
In gist, my k1100 runs after m-unit installation but it would suddenly black out when test drive (for like 5 mins run).  Hall sensor and the heat shrink of the ignition unit checked correct and therefore i suspect there might be sth wrong with my wiring.
  • Hong Kong
  • K1100RS 1993
Offline Kaos
« Reply #28 on: January 22, 2025, 06:51:09 AM »
Did you blow the fuse? If so, what's amps on the fuse?
Otherwise its overdraw from a single outlet and your m-unit will shut down. It has this protesctivs measure built in.
This is the (my own) wiring diagram i am running on the same v2.1 ecu.
https://www.motobrick.com/index.php?topic=15838.0
Works on all v2.1
Offline BCK2WRK
« Reply #29 on: January 22, 2025, 07:07:57 AM »
Oh I guess I might have overdraw the output,
But meanwhile can you share your diagram in a higher resolution version, please
  • Hong Kong
  • K1100RS 1993
Offline Kaos
« Reply #30 on: January 22, 2025, 11:45:46 AM »
Do keep in mind a single output is 12v and 10A max.
* K100AndAbitWiringDiagram.png (47.38 kB . 696x576 - viewed 1341 times)
