Replacing Crankcase Gasket for K100
Topic: Replacing Crankcase Gasket for K100 (Read 4778 times)
mitchfloyd
Curious
September 15, 2024, 06:39:58 AM »
Hi, I don't want to drain the coolant and remove the hoses, what can I do to replace the crankcase gasket for K100. Looking forward to your comments? Thanks.
England
K100
Laitch
Faster than a speeding pullet
Administrator
Re: Replacing Crankcase Gasket for K100
Reply #1 on:
September 15, 2024, 06:00:10 PM »
Welcome to the scrum, mitch!
There is only
one
hose that passes through the crankshaft cover. Its upper end attaches to the radiator; its lower end attaches to the water/oil pump. If you don’t want to drain the coolant then lift the cover—including its hose—from their attachment points to the engine, radiator, and pump so you can install the gasket, you probably should find somebody who will do it for you.
You can reuse the coolant if you drain it into a clean container but if the last time it was replaced is unknown or it looks discolored, replace it.
How to replace the coolant is described on p.17–13.0 in
the K75/K100 2V shop manual downloadable from this site
Along the Ridley in Vermont.
1995 K75 102,000 miles
daveson
Reply #2 on:
September 15, 2024, 07:02:01 PM »
You don't have to remove the radiator hose, just remove the crankcase cover, it will pivot around the hose, which is flexible.
Victoria, Australia
Current; '85 K100RT~100,000km; four other bricks. Past; Vulcan 1500, V Star 650, KLX 250(dirt bike) TT250(dirt bike)
Laitch
Administrator
Reply #3 on:
September 15, 2024, 10:04:24 PM »
Quote from: daveson on September 15, 2024, 07:02:01 PM
. . .it will pivot around the hose, which is flexible.
Gotta like that one!
Let us know how it works out, mitch.
daveson
Reply #4 on:
September 15, 2024, 11:04:35 PM »
There might be a bit of oomph and a bit of aah involved.
Victoria, Australia
Laitch
Administrator
Reply #5 on:
September 15, 2024, 11:27:24 PM »
Post a public video of the process on YouTube, mitch, and post the link here.
Laitch
Administrator
Reply #6 on:
September 16, 2024, 12:10:13 PM »
Here we go—complete with an oil bath! It could be possible. Cleaning oil from mating surfaces could be challenging. I'd rather remove it.
daveson
Reply #7 on:
September 16, 2024, 04:21:58 PM »
That's a good reminder that it would be easier to deal with the oil if it hasn't been started for a day or so, and parked on the side stand, as well as when doing the job.
Victoria, Australia
Laitch
Administrator
Reply #8 on:
September 16, 2024, 05:10:03 PM »
It's also a good show-and-tell example of a pressurized oil system.
