Author Topic: Temp sensor test  (Read 8670 times)
Offline Lbxpdx
Re: Temp sensor test
« Reply #25 on: August 19, 2023, 05:24:27 PM »
When I ground it to #13, I get 10M ohm. When I ground it to the battery ground bolt, I get 3.5 M ohm.
  • Portland
  • 1994 K75S, 1992 K75RT, 1972 R60/5 & 1977 R100S
Offline Lbxpdx
« Reply #26 on: August 19, 2023, 05:27:53 PM »
Do you believe your probe in that photo is on pin # 10? If so, how do you reconcile that with the attached diagram from the LE Jetronic manual at the link I posted?
Holy sheep shit!  I’ve been reading the pins wrong the whole time.   Crazy that I would get continuity at the pin I thought was #10.
  • Portland
« Reply #27 on: August 19, 2023, 06:29:03 PM »
What happened at pin #4 is irrelevant.
Offline Past-my-Prime
« Reply #28 on: February 29, 2024, 08:20:07 PM »
Haha well here’s a reward for going through old posts!   :laughing1:
I’ve done the same. . . Trying to fix something that wasn’t broken, until I ended up breaking it!  I feel slightly less alone now.
