Author Topic: 1985 K100RS valve cover gasket  (Read 5951 times)
Offline Lawrence
« on: December 28, 2011, 11:31:07 AM »
Contemplating checking the clearances on the valves, is it typically possible to reuse the cover gasket, or should I have a new one at hand when I check the valves?
TIA
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
Offline Inge K.
Re: 1985 K100RS valve cover gasket
« Reply #1 on: December 28, 2011, 12:50:10 PM »
No problem to reuse the gasket, if the rubber don`t have become to stiff.
On the oldest one of my bikes I`ve changed it one time during 25 years.
Apply a small amount of sealant at the joint where the timing cover and head meets,
and at the camshaft cutout in the rear end.
Inge K.
  • Norway
« Reply #2 on: December 28, 2011, 11:05:50 PM »
Can't say as I recall who made the statement but...." as sure as you have a part on hand you most likely won't need it."  "cause when you don't...... you will".
1995 K1100LT 0302044 (R.I.P)
