Author Topic: Oops  (Read 7580 times)
Oops
« on: January 20, 2023, 10:54:43 AM »
I move the K outside a week ago to make room for some other projects in the garage, hated to do that but at least had a cover for it.  Well, wouldn't you know big storm with 50mph gusts caught that cover and blew it over.  Not the first time it been sideways but that damn thing has gotten MUCH heavier since the last time I dropped it!  Minimal damage, broken hinge on saddlebag and cracked mirror, maybe tweaked forks.  Guess I ought to figure out how to add some tie downs now
Offline beemuker
Re: Oops
« Reply #1 on: January 20, 2023, 01:55:27 PM »
or just leave it uncovered.
  • Panama City, FL
Re: Oops
« Reply #3 on: January 20, 2023, 04:48:12 PM »
I don't know, I had one of those chocks and got rid of it after only using it once because it was unstable and scared me when I was working on the bike.  Bricks are just too top heavy in my opinion to work with those things.
My suggestion is to leave the cover on, but do a "hurricane wrap" to pull it close to the profile of the bike and prevent any slack in the cover from catching the wind.  Works pretty well for keeping mainsails in place in heavy winds.
Simply get about 40' of 1/4" line and starting at one end of the bike wrap the line around covered bike about 6 or 7 times.  The idea is to secure the cover to the bike so it can't flap around and present more cross section to the wind than the naked bike.  Should only take a minute or two to get a good wrap.
If you are expecting heavy wind, it would help if you moved the bike to a position where it is close to a wall that can act as a windbreak.
Offline Past-my-Prime
Re: Oops
« Reply #4 on: January 20, 2023, 09:45:25 PM »
I'd move a bike with a sidecar outside if I had a choice. Those are a lot harder to blow over
Re: Oops
« Reply #5 on: January 20, 2023, 10:20:04 PM »
True, but that's my winter ride and it likes being in a nice cozy garage.  That's a drag because it's a gowdamn big sonofabitch!
Re: Oops
« Reply #6 on: January 21, 2023, 03:00:00 PM »
The weather forecast for a storm should tell you which direction the wind will be blowing. If you have to leave the bike outside then have it pointed into the wind, preferably with another vehicle in front of it. If the bike doesn't get hit broadside by the wind then it shouldn't tip over.
Online Laitch
Re: Oops
« Reply #7 on: January 21, 2023, 05:29:36 PM »
That is why an anemometer should be in every Brick owner's tool kit along with a copy of the Ashley Book of Knots, the 40' of line for lashing the cover, and the Slim Jims.
Re: Oops
« Reply #8 on: January 21, 2023, 05:49:36 PM »
I failed to take advantage of a unique K bike feature, idiotic sidestand lean.  I had angled the bike so the stand was on the uphill side of the sloped driveway, negating the extra lean.  If i had angled it downhill it would have been much harder to blow over a bike leaning into the wind at a 45 degree angle.
