Author Topic: New Member From Wisconsin  (Read 10735 times)
Offline CrestK75RT
« on: September 17, 2022, 03:54:33 PM »
Hello,
Thanks for letting me join! New to BMW motorcycles. Just acquired  a 1992 K75RT with 20,000 miles, Great fun!!!
  • Wausau
Re: New Member From Wisconsin
« Reply #1 on: September 17, 2022, 06:40:58 PM »
Welcome! You've purchased a keeper. Congratulations.
« Reply #2 on: September 17, 2022, 09:34:26 PM »
We pretty much let anybody join  :laughing1:
« Reply #3 on: September 17, 2022, 09:57:30 PM »
Laitch is proof of that.  :laughing4-giggles:
Congrats. Looks to be in very good shape at only 20K. Your job is to now put some serious miles on it.
92 is a good year. It's got the Showa forks.
« Reply #4 on: September 17, 2022, 10:50:40 PM »
 4265249878
Offline CrestK75RT
« Reply #5 on: September 17, 2022, 11:48:50 PM »
Thanks again,
The bike came the the original comfort windshield, the one with adjustable side flaps. Any idea if I can get replacements for the black plastic connectors?
Mine are cracked and broken.
  • Wausau
« Reply #6 on: September 18, 2022, 06:48:07 AM »
If you're referring to #12 in the diagram below from MaxBMW, Max indicate they might have a source for one of the sides. You could give them a call on Monday. They're costly. Fabricating them yourself is an option.
« Reply #7 on: September 18, 2022, 10:02:58 AM »
Are you talking about the black plastic hinges that the side flaps are attached with?  The MaxBMW parts list doesn't show them anymore.  They seem to have been replaced with pricey clear plastic parts.
46 63 2 303 613    HINGE
46 63 2 303 614    HINGE
They cost almost $35 each and there are four of each used.  If it were my bike, I would be looking for a used windshield from somebody who is hacking up an RT to build a cafe.  They do show up from time to time on eBay.
« Reply #8 on: September 18, 2022, 10:09:20 AM »
Your ride probably came with the BMW rider's handbook but if it didn't, you can get one and also a service manual at this Motobrick link.
« Reply #9 on: September 18, 2022, 11:45:39 AM »
Regarding those comfort windshield side flaps:  I have been riding my RT for 8 years and 50K miles and have found that those flaps have pretty much no effect on the air flow to the rider behind the shield.  About all they do is keep my shoulders sorta dry in the rain.  The hinges are not worth the $300 that a set of four would cost.
As I mentioned above, they do show up on eBay with complete windshields, but that requires waiting for and buying the complete windshield when they do show up.  This can cost upwards of $150 when shipping is included.
As a temporary fix that you might find quite usable you could get a piece of black ABS thermoforming sheet about 1/8" thick and cut pieces 3/4" x 2 1/2".
https://www.ebay.com/itm/143827023397?var=443025356214&hash=item217cc23625:g:qYcAAOSw~X1fpY0i&amdata=enc%3AAQAHAAAA8O9NMV0NRKkt01%2BocMmG%2Btp9uk%2B6ijq8eEoNFbaRAA1X1BQdtAyU8Y5blgH1b1iuGr5Fx6kJRqQ%2FJue6hMlVE4qw%2B0StBIR7dGbUUEhy3BVjouvvuruo1Ivtacgh5h507umHL%2Bc5dEocPjml5PXfg2bwghY1NmWl%2B14p46Y7lQ4XD4kY7pv8ceW6lbI9kt0w33v0hrEPWIhxcS2eNCkEYNBf00AWs9fuxTFwV%2F91QViR3Sv05aEbNzLdIbjtbI5OhtOr8ew5Mk4cfKY%2FazLqLjDpo140Ht90xQXmrSiXDvzPFhxoBaigWHB5Fi6xzuwC5Q%3D%3D%7Ctkp%3ABFBMkNDJlOpg
Drill two 4mm holes 1 15/16" apart.  Make two pieces for each hinge you want to replace.  Use the pieces to hold the flap in place with 4mm machine screws.  Sure, the flaps won't be adjustable, but you don't really need them to move.  I am pretty sure that with an hour or so of labor and 10 bucks you could have a very usable solution.
« Reply #10 on: September 18, 2022, 12:15:30 PM »
I had those flaps on my K75RT and really liked them.  In hot weather I could flip them forward and they gave much improved air flow to the rider.
« Reply #11 on: September 18, 2022, 12:21:16 PM »
You must have a different version of the comfort flaps than I have.
« Reply #12 on: September 18, 2022, 01:04:08 PM »
I don't have a close-up by my K75RT's windscreen had a big flap on each side. They looked dorky when flipped to the front but really helped keep me cool in hot weather.
« Reply #13 on: September 18, 2022, 01:44:28 PM »
Yep, same as mine.  Maybe the air is different where you ride.
Offline CrestK75RT
« Reply #14 on: September 18, 2022, 03:38:57 PM »
Thanks for the guidance. I would like to keep the bike stock and I think the flaps will help giving some needed air flow on the hot summer days. Seems the like the RT holds the heat.
  • Wausau
Offline Past-my-Prime
« Reply #15 on: September 18, 2022, 09:28:46 PM »
It does.
:) It's why you ride north!
« Reply #16 on: September 18, 2022, 10:52:19 PM »
It's why I do my touring in October.  Sometimes A little extra heat is welcome.
« Reply #17 on: September 19, 2022, 09:03:56 AM »
Maybe this document about Brick heat management will interest you, Crest.
