Author Topic: 95 K75 Kafe' Racer Project.  (Read 44810 times)
Re: 95 K75 Kafe' Racer Project.
« Reply #50 on: October 15, 2022, 08:35:56 AM »
All of that spray paint is going to throw the clutch assembly out of balance. :laughing4-giggles:
Did you consider getting it media blasted?
Offline JimVonBaden
  • BMW Kool Aid
« Reply #51 on: October 15, 2022, 09:16:31 AM »
I didn't even consider removing it. I don't have an alignment tool, and it is not going to hurt anything anyhow.
  • My garage
  • 1995 K75RT, many others
« Reply #52 on: October 15, 2022, 10:29:33 AM »
You don't need the alignment tool. (I have one and don't use it.)
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchnospecial/clutchnospecial.htm
If it were me, on a bike with that many miles, while I have the trans off, I'd pull the clutch apart just to measure the clutch plate so that if it's near the end of it's life then I could replace it (or at least know how much life is left.) Min spec is 4.5mm. New is 5.55.
It might also not be a bad idea to replace the clutch nut O-ring with a Viton one. (19x4)
The six bolts around the perimeter that hold the clutch together can be sticky. Use heat and a good Allen wrench when removing them. They have shallow heads and can strip if you're not careful. DAMHIK :laughing1:
IN THEORY, you're supposed to replace those six bolts and their lock washers with new but I re-use the old ones and it's never been an issue.
A mini nail puller can be used around the perimeter to pry the clutch apart:
https://www.ebay.com/itm/254451833276
Offline JimVonBaden
  • BMW Kool Aid
« Reply #53 on: November 30, 2022, 11:07:23 PM »
Project is on hold as I refurb a flipper Kawasaki Versys.
https://www.kawasakiversys.com/threads/barnish-find-2009-versys-650.229136/unread
I should be back to it before Christmas.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #54 on: December 01, 2022, 11:32:48 PM »
Tire day coming up. Versys, GS and Kafe'
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #55 on: April 20, 2023, 11:11:16 PM »
Back on the K.
Cutting, grinding, painting the frame and mild fab.
Continued...
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #56 on: April 20, 2023, 11:13:20 PM »
Engine looks like new compared to the miles.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #57 on: April 20, 2023, 11:14:41 PM »
Some reassembly. Looking pretty good.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #58 on: April 23, 2023, 01:12:08 AM »
Just a little mock up touch-up while cleaning and sealing my garage floor.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #59 on: June 24, 2023, 04:12:26 PM »
Changed direction on the fender. I didn't like the straps, so I filled the holes and made brackets to mount the fender under the mounts.
Finished up the headlight/fairing mount:
Added a stabilizer bracket to the instrument cluster:
Removed the front wheel for paint:
Started prepping for paint:
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #60 on: June 28, 2023, 11:42:07 PM »
Still working the paint prep, between travels.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #61 on: July 03, 2023, 07:44:03 PM »
Getting close to paint, likely tomorrow if the weather cooperates!
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #62 on: July 04, 2023, 02:02:28 PM »
Paint done. Primer first!
Next color, root beer.
Then Clear:
Lots left to do, but am on the home stretch.
  • My garage
« Reply #63 on: July 05, 2023, 11:09:05 AM »
Helpful setup details in those photos, Jim. 112350
Offline JimVonBaden
  • BMW Kool Aid
« Reply #64 on: July 08, 2023, 09:58:06 AM »
A little more progress. Trim on the edges, screen on, seat assembled, valves in the rims.
Today I wire all the lights and finish the hoses.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #65 on: July 08, 2023, 10:57:03 PM »
Wired up the rear lights and installed the inner fender, then the tail light. It is all surprisingly bright.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #66 on: July 12, 2023, 08:19:37 AM »
Finally off the lift and back on wheels, (what a pain that was doing alone). Mostly mock assembly. Still a lot to do.
  • My garage
Offline AtLarge
« Reply #67 on: July 12, 2023, 10:25:15 AM »
Well done!   :twothumbsupp
  • IA
  • 1994 K1100RS
Offline JimVonBaden
  • BMW Kool Aid
« Reply #68 on: July 14, 2023, 09:15:53 AM »
A few minor things done. Also finally got the lower radiator hose through the hole in the crank case cover, PITA!
Had to reuse the left side upper radiator hose, the replacement was too short.
Added the new SS brake lines. Not happy with the front, too tight. This is full extension and has a bit of slack, but not as much as I would prefer.
The rear wasn't much better, but will do. These were for a K75C according to the seller, so should have been a better fit.
Much more to go.
  • My garage
« Reply #69 on: July 14, 2023, 10:00:25 AM »
It was never intended to go through the cover on a K75RT. I can imagine the conflict echoing through your shop. Submit! Submit! YOU WILL SUBMIT!  :laughing4-giggles: Ok, ok, man. Chill.
Offline JimVonBaden
  • BMW Kool Aid
« Reply #70 on: July 14, 2023, 10:05:03 AM »
For sure. However, if you remove the wire bracket and tilt the radiator back to the original position, it allows it to be done.
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #71 on: July 16, 2023, 08:52:19 PM »
Brakes, side panels, and small bits done.
Runs great:
  • My garage
Offline JimVonBaden
  • BMW Kool Aid
« Reply #72 on: July 19, 2023, 08:52:34 AM »
Dug it out of the shop and took it for a short ride. Everything works and it rides fine.
A couple of glamor shots then put it away with the others until I get the mirrors and new ignition switch.
  • My garage
« Reply #73 on: July 19, 2023, 09:13:12 AM »
Normally, I don't like cafe conversions.  I consider them hacked up and ruined machines, but your bike seems to get it right.  I really like the fairing which works nicely with the OEM "lunchbox" instruments.  The color scheme of the paint work goes well with the blacked out mechanicals.  Even the seat, which makes my a$$ cringe, looks good with the overall lines of the bike.
I also like that your photos avoid the macho "urban warrior" theme with the graffiti covered dumpster surrounded by garbage and empty beer cans.  That cliche is such a gay joke. (Not that there's anything wrong with that.)
All in all, very nicely done!  You have a true gentleman's cafe bike.  It would go well with a tweed jacket and corduroy slacks.
Offline JimVonBaden
  • BMW Kool Aid
« Reply #74 on: July 19, 2023, 09:56:45 AM »
Thanks, I have never been a good Cafe Racer fan. They often look contrived and or trash art more than functional. To be fair, I wouldn't want to ride this far. The riding position and handlebars don't work well with my 60 year old back and large tummy. That said, it rides pretty good and has all the stuff to make it legal and a generally all weather bike.
As for the instruments, yeah, I considered a different cluster, but the cost and reduced functionality weren't in the cards for a bike I never really intended to keep.
I has been a fun project though, and I will likely sell it for just enough to break even given the higher miles on it.
  • My garage
