Author Topic: 1985 KRT 100 crazy starter switch  (Read 3347 times)
Offline pinhead
« on: March 24, 2022, 05:59:20 PM »
Has anybody taken apart there starter motor button switch on these bikes?  Mine automatically starts engine when I turn switch on without even having to press button.  I took apart switch housing and there doesn't appear to be any spring that returns button to normally open position.   There are 2 little springs for the activation of the kill switch which is incorporated in the starter switch housing.
  • sacramento, ca
  • 1985 RT 100
Re: 1985 KRT 100 crazy starter switch
« Reply #1 on: March 24, 2022, 06:43:17 PM »
Does the starter button have any spring action to it? If it does, this condition might instead be caused by starter relay contacts stuck together and knocking on the relay with a screwdriver handle could release them.
Offline pinhead
« Reply #2 on: March 25, 2022, 03:19:28 PM »
There is no spring action in switch and no where I can see where you can get at any spring that might exist.
  • sacramento, ca
  • 1985 RT 100
« Reply #3 on: March 25, 2022, 06:15:06 PM »
If you're using Firefox browser and a Mac with Catalina OS, you might not see the attached photo. Switch to Safari.
« Reply #4 on: March 25, 2022, 06:42:54 PM »
I haven't experienced this problem but there's sufficient online information to guide a victim who is experiencing it.
What seems to have happened is the pin on the left side of the photo dropped from the green button's shaft on the right side of the photo and is making a permanent bridge between the contact blades. This causes both the starter to engage when the key is turned to On and also the button to jam against the pin when it's pushed. The button seems to be held in position by a flexible covering glued to the perimeter of its housing. You'll get more clarity about exactly what has gone wrong when you disassemble it to that extent.
See the story at HARDTOPTIRE.
Offline pinhead
« Reply #5 on: March 28, 2022, 09:02:13 PM »
That website says it only sells to European countries, unfortunately.  Yes I think there is a green rubber boot that attaches to the button and is responsible for the return of the button, but where could I ever buy something like that??  I tried making one and it didn't come out right.
  • sacramento, ca
  • 1985 RT 100
« Reply #6 on: March 28, 2022, 09:49:56 PM »
This should get you going.  Same part number as the one on your bike.
https://www.ebay.com/itm/224786893600?hash=item345657cb20:g:~-oAAOSwvUVh4IAi
« Reply #7 on: March 28, 2022, 10:08:05 PM »
. . . I think there is a green rubber boot that attaches to the button and is responsible for the return of the button . . .
Try this, if all else fails,  icon_cheers  or this.
Offline pinhead
« Reply #8 on: March 29, 2022, 04:45:13 PM »
Very inventive and nice!  I am glad to see  that others have faced the same dilemma that I am in and have figured it out!  thanks
  • sacramento, ca
  • 1985 RT 100
