Author Topic: Fuel pump manufacturer noise difference?  (Read 7917 times)
Offline schrocketeer
« on: May 14, 2021, 02:50:06 PM »
Are the Bosch fuel pumps noticeably quieter than the Noris, or the Chinese eBay pumps?
Beemer Boneyard shows the Bosch (just the pump) as $240, Noris as $190 (https://www.beemerboneyard.com/k71011k1ak1u.html ). eBay has the Chinese version for $70.
3 years and 20k miles ago, I installed a Chinese eBay version, and have had no issues operationally with it.
It crosses my mind however, to wonder if it would be worth breaking the piggy bank, to have a much quieter ride?
  • North Alabama
  • 1985 K100RT very original
Ken
Re: Fuel pump manufacturer noise difference?
« Reply #1 on: May 14, 2021, 05:27:20 PM »
See http://www.motobrick.com/index.php?topic=10054.msg85798#msg85798 mine is still running just fine. And it has been subjected long hot fast multi day runs in OZ summer temperatures that had the fuel in the tank bubbling.
« Reply #2 on: May 14, 2021, 06:39:22 PM »
What is reasonably quiet, Martin? Is it Huey-at-two thousand-feet quiet, honeybee quiet, hummingbird quiet, library quiet, funeral home viewing room quiet, mute swan quiet, outer space quiet? Some of these pumps can keep a body awake when it really needs to sleep during those long rides.
« Reply #3 on: May 14, 2021, 07:03:31 PM »
I just checked it, with a near full tank you can't hear the pump even with the fuel cap open. The OEM that I rated it as quiet as compared to others could always be heard. On our 4 day bike marathon on 40C plus days with a low fuel level (under 5 litres left)the noise was quite noticeable but disappeared when the tank was full. From my observations noise level is dependant on fuel level and temperature of fuel.
« Reply #4 on: May 14, 2021, 07:05:59 PM »
When I started riding bricks, I couldn't believe how loud the OEM pump was. I've got used to it now, it seems now to be as quiet as an angels fart.
« Reply #5 on: May 14, 2021, 08:31:42 PM »
The stock one gets loud when there's very little fuel since the tank is then a bigger resonating chamber.  When I did my first tours on my K75RT it was so loud when it got near empty that I thought there was something wrong with the bike since I didn't know any better. (This  was wearing a half helmet and before I learned that you should always wear earplugs when you ride to keep from going deaf later in life.)
Tags: fuel pump noise sound
