Author Topic: Custom LED Brake Light  (Read 28999 times)
Offline bobvans
« on: March 02, 2021, 11:31:32 PM »
Back when I got my '86 K100 I wanted to improve safety a bit by adding an LED brake light that strobes when brake is applied.  It was a bit of a hack job in that I bought one of the standard tail lights Custom LED offered and cut up my tail light to make it fit.
* IMG_1002.JPG (43.87 kB . 432x576 - viewed 2286 times)
Now that I have a'96 K1100, I wanted to add the same capability but make it look stock and have it light up the entire tail light like this picture someone posted somewhere...
* Tailight.JPG (50.41 kB . 768x576 - viewed 2209 times)
But I want it to strobe like this... except I won't use the turn signal feature since I want to continue using the original turn signals.
So I bought a new tail light from Max BMW, cut it open with a dremel and sawzall.
* File_000.jpeg (62.03 kB . 768x576 - viewed 2293 times)
And am now working with Custom LED to have a... you guessed it, custom LED board made up to hopefully somehow fit into the tail light.  Here's the board design we settled on...
* Custom LED R3.jpg (28.2 kB . 768x396 - viewed 2156 times)
  • Vancouver, WA. USA
  • '85 K100 (Red), '96 K1100RS (Graphite), '85 K100RS (Blue, "Project Bike")
Offline AtLarge
Re: Custom LED Brake Light
« Reply #1 on: March 03, 2021, 06:35:35 AM »
 :popcorm
  • IA
  • 1994 K1100RS
Offline bobvans
« Reply #3 on: March 03, 2021, 12:23:48 PM »
https://www.skenelights.com/online-store/P3-Lights-p199537706
I've seen those but really want the entire tail light to strobe and be super bright.  Hopefully I sized the board correctly and can get it all back together and look decent :laughing4-giggles:.  I'll provide an update in a few weeks when I get the board.
« Reply #4 on: March 03, 2021, 01:56:35 PM »
Will your board act as running lights as well as a strobing brake light?
Offline bobvans
« Reply #5 on: March 03, 2021, 07:02:32 PM »
Yes, running lights, brake lights, and integrated turn signals (if you want).  The strobe affect on braking is selectable... 11 different options.
* Strobe pattern.jpg (71.48 kB . 768x446 - viewed 2244 times)
« Reply #6 on: March 04, 2021, 11:02:43 AM »
11 options! God bless America—or elsewhere—whichever is applicable!
Offline bobvans
« Reply #7 on: March 04, 2021, 12:01:56 PM »
Ha ha... can't have too many options  :laughing1:.
Offline Past-my-Prime
« Reply #8 on: March 04, 2021, 08:54:59 PM »
Can I have three quick flashes, then three slow flashes, then three quick flashes, repeat?
Offline bobvans
« Reply #9 on: March 04, 2021, 10:27:13 PM »
That would be with the 4 way flashers option  :laughing1:
« Reply #10 on: March 05, 2021, 12:05:24 AM »
Despite the term SOS, I believe the correct pattern is 3 quick, 3 slow, 3 quick, 3 slow, etc.
Offline bobvans
« Reply #11 on: March 24, 2021, 07:50:35 PM »
Received the custom LED board on Monday.  Now the challenge will be to cut away the right amount of the tail light's plastic support structure to fit the board while maintaining enough structural strength of the overall assembly.  I think a band saw would make the task a lot easier.  May need to take this to work and see if I can get into the model shop.
* LED Board.jpeg (67.86 kB . 768x576 - viewed 2115 times)
Offline bobvans
« Reply #12 on: March 24, 2021, 08:10:26 PM »
* LED Board 01.jpeg (56.59 kB . 768x576 - viewed 2104 times)
* LED Board 02.jpeg (58 kB . 768x576 - viewed 2109 times)
I want to get it mounted in this location so need to cut away the part of the housing that's in the way.
* LED Board 03.jpeg (35.95 kB . 768x576 - viewed 2148 times)
Offline bobvans
« Reply #13 on: March 25, 2021, 04:53:22 PM »
Started cutting away on the tail light assembly.  A ways to go yet but this gives me a feel for how it will turn out.  Looks like the structure should be in good shape, even after the hacking is done.
* Housing Mod 02.jpeg (55.79 kB . 768x576 - viewed 2042 times)
* Housing Mod 01.jpeg (41.16 kB . 768x576 - viewed 2109 times)
« Reply #14 on: March 25, 2021, 11:49:13 PM »
How many of those lights serve as brake lights, how many serve as tail lights and how are they arrayed, or do they all have a double function?
Offline bobvans
« Reply #15 on: March 26, 2021, 07:32:01 PM »
I haven't confirmed yet, but they're all supposed to be double function (running and brake lights).  For turn signals half would flash on and off.
I'm chomping on the bit to due an A/B compare... so may do that before I get the actual retrofit done.  On that note, I'm going Dremel vs band saw and my Dremel crapped out on me... may need new brushes :idunno:.
Offline Rcgreaves
« Reply #16 on: March 27, 2021, 12:15:51 AM »
 :popcorm "Cuuuul".....
Doing “better than I deserve"
Offline bobvans
« Reply #17 on: April 02, 2021, 12:52:45 AM »
Got my Dremel back online so did some more cutting.  It's almost there... just a little more trimming to level out the surface the board will lay against.
* Custom LED 30.jpeg (63.45 kB . 768x576 - viewed 1962 times)
* Custom LED 31.jpeg (33.64 kB . 768x576 - viewed 1981 times)
* LED Board 12.jpeg (54.19 kB . 768x576 - viewed 2069 times)
* LED Board 10.jpeg (38.11 kB . 768x576 - viewed 2158 times)
Offline bobvans
« Reply #18 on: April 05, 2021, 04:37:52 PM »
After a bit more trimming with the Dremel, I've got it to where I think it needs to be.  Decided to close off all the openings with some pieces I cut from electrical boxes.  Hot glued them in place.
* Housing Mod 07.jpeg (27.19 kB . 768x576 - viewed 1977 times)
* Housing Mod 05.jpeg (49.83 kB . 768x576 - viewed 2071 times)
Next I need to drill a couple of holes for a couple of mounting screws along with adding something for the screws to screw into.  I'm going to try using the two drilled screw bosses from the electrical box.
Offline bobvans
« Reply #19 on: April 05, 2021, 10:51:38 PM »
I wasn't sure about what to do with the brake light "magnifier" part of the tail light.  Then remembered that the entire tail light will be the brake light so decided to just cut it off and leave only the clear lens part for license plate illumination.  I glued it with a combination of super glue and hot glue... super hot glue  :laughing1:.  Actually just super glued it on and put the hot melt over the joint for good measure.
* Magnifier 01.jpeg (82.79 kB . 768x576 - viewed 1985 times)
* Magnifier 03.jpeg (82.92 kB . 768x576 - viewed 2199 times)
* Magnifier 02.jpeg (59.21 kB . 768x576 - viewed 2062 times)
Just to add... I had to trim the inner walls of the red lens to allow the lens to fit over the circuit board.
« Reply #20 on: April 05, 2021, 11:45:10 PM »
Looks interesting.  Keep posting.
Offline bobvans
« Reply #21 on: April 06, 2021, 03:10:12 PM »
Looks like using the screw bosses off the electrical switch box is going to work nicely.  My plan is to attach the board using the bosses as nuts.  Get the board in final position and then mark location of the bosses.  I'll epoxy them in place, mount the board to hold them in place.  Then I'll add some epoxy between the boss and adjacent wall for good measure...
* Screw Boss.jpeg (48.16 kB . 768x576 - viewed 2030 times)
* Screw Boss 01.jpeg (23.4 kB . 768x576 - viewed 2023 times)
* Screw Boss 03.jpeg (25.11 kB . 768x576 - viewed 2128 times)
* Screw Boss 02.jpeg (44.76 kB . 768x576 - viewed 2159 times)
« Reply #22 on: April 06, 2021, 08:57:23 PM »
I like it!  Keep us updated on your progress.
During some recent airhead work for a friend I installed a commercial LED taillight replacement which really lit up the running and brake illumination but I was a bit disappointed that there were no flashing options.
Offline bobvans
« Reply #23 on: April 07, 2021, 11:54:11 AM »
I know what you mean.  I really liked having that strobe on my K100 to give extra visibility when at a stop light.  If I was off the brake but see a car coming up from behind I'd squeeze the brake lever a time or two to make sure they're slowing down. Seems it would maybe catch someone's attention if their texting.  There was someone that got killed at an off ramp last year not too far from my house.  Driver was under the influence and didn't see the vehicles stopped at the light, I guess.  Motorcyclist got caught between her and the pickup truck in front of him.  Not sure a strobe would have made a difference in that case though.
« Reply #24 on: April 07, 2021, 12:00:31 PM »
Drivers regularly crash into lit up police cars parked on shoulders. In attempts to avert that, intermittently flashing, rather than pulsating, strobes have been developed. There's a body of evidence that suggests pulsating strobes can attract some drivers rather than alert them. It's a jungle out there.  :laughing4-giggles:
