Internet was out here at the house this Christmas morning,... I wonder if I brought electron virus home from the shop?
Reboot internet worked here, hope it might work on the ABS sometime also.
Yes, I too believe in the ABS, and credit it at least once for saving the day! Traffic light in Santa Monica changed to green, we all start moving, I glance Left, look forward,... YIKES! Car in front had stopped! I was actually visualizing the flight over the top, when the bike did the KaChunk / KaChunk .... and stopped!! I couldn’t believe it. It was amazing and much appreciated. I want my ABS !!!
I will try the plug disconnect for a day, can’t hurt. Then do the reset again.
To recap, Starting at the last time it was working:
> In the shop doing fairing paint work. (This after deciding it was worth the effort, after a short ride proved bike is running OK, and did not have ABS issue)
>Once in awhile, I’d turn the Key, check the lights, listen to the Whine stop, and look at the VoltMeter. Fully aware that the old battery was likely on it’s last legs, and amazed it started the bike before. Bike is connected to a low 2 amp battery tender all this time.
> At some point, I actually hit the starter, and the lights died, and the short crank quit, so battery was dead. Why now after cranking before I thought? Voltmeter confirmed low battery was down to 8 volts. DOA
> Commit to a new $110 Scorpion AGM, get it online (Battery Stuff), and do the remove / replace.
> The RR requires the 2 “computers” be removed. As trained, disconnect the Neg Batt wire to kill any stray power to the bike first. Pull off the multi-pin connectors, remove boxes, clean cables, RR battery, reassemble.
> At that point, I know I tried the new battery while in the shop by Lights / Horn / and Crank. All seemed OK, so continued Paint.
> When fairings finally back on the bike, DMV Non-ops renewed, Hagerty Ins back up, go out side and take a ride.
> ABS flashing, Brakes checked, now ABS and red Caution both flashing. That is still the condition at present.
