Hey all,
I've noticed my bike's idle seemed off. It didn't seem as smooth as it should so I've been looking into the synchronizing the throttle bodies (which seems to be a misnomer since the adjustment for synching them shouldn't be touched...?). I made a manometer similar to this one , and when I first checked the readings on it, cylinder 3 fluid was much lower than 1 and 2. As I adjusted the idle adjuster screws (brass) for each I was able to pull the vacuum levels closer, but it seemed to run worse once they pulled the same vacuum.
So I started to make sure the throttle position sensor was set right. Seems like to set it there should be a click just as the throttle is turned and at full. I don't get another click at full throttle. Still didn't seem right to me.
I tried to start from scratch so I lightly tightened the brass screws then backed them out 1.5 turns. I set up the manometer and adjusted from there. They're closer than before but idle is no better than when I started. I had to raise the base idle screw once I did this because it was idling low at 850 (1000 range now).
I also saw a thread that someone set cylinder 3 idle screw 1.5 out from bottom and then only measure cylinders 1 and 2 to pull the same regardless of cylinder 3.
I sprayed some starting fluid around to see if there were any leaks and I got no increase in idle from the bike at any point. I feel like I missed the order things should have been done and ended off worse than before. How do I get back to a base for checking the idle for adjustment?
