Author Topic: MDAY15 -K75 Strut rebuild parts- Enduralast at EME v OEMv SEALMATE  (Read 24497 times)
Offline Rcgreaves
7/15/20-lots of additional items added as I disassembled and discovered wear items.
Laitch abridged version:
A quick MB search didn't yield any definitive gripes with Enduralast fork seals, so:  Should I use OEM only or shall I save significant coin on aftermarket seals?  Ok, full disclosure- money is tight, I ordered the aftermarket seals today...
Fork Seal and Dust Cap Kit - BMW K75, K100 ; 31 42 1 451 829, 31 42 1 451 478, 31 42 1 450 127 / EnDuraLast   1   $33.99  shipping was $14 so $49 shipped.  I believe with free shipping and 15% off a part Max was $105. That Germany rubber is special after all....
You wish stuff like this would show up in February during an ice storm, but I grant it is a stretch to imagine a fork seal failing in the garage as I make "pffffting beemer sounds" on the center stand, right?
I did a 500 mile "yee haa", a couple of weeks back from the WI Door Peninsula home, and at dismount in my garage, my right strut slider was coated not only in evergreen pollen but fork oil goo too and bleeding fast....  fork oil goo too, amazing what comes out with a strong cup of coffee and good night's sleep.
So: via Max, the resto parts including the "Johnny says I must bushings" eh eh, that's me coughing up my billfold, $165 shipped.  that's for the rubber bits 2,4,6 If memory serves..
Euromotoelectrics.com offers a seal "kit" of seals and dust caps for roughly half the OEM .
So I'll snag the Max 15% off for the bushing order and  ask:
"Am I ok with Enduralast Aftermarket seals and dust cap?"  Will they last?"
Heres the bushing info.
BILLING INFO:
Name: R Greaves      ZIP: 53554-9510
Card: VISA  XXXX XXXX XXXX 5709
   Part#           |Description                             |  Each      |  Total
  2/31422312705    |GUIDE BUSH (from 08/91)                 |      $21.54|      $43.08
  1/36131181082    |PLAQUE WITH ADHESIVE FILM               |       $6.77|       $6.77
        SubTotal:       $49.85
        Shipping:        $0.00  (Free Shipping-$0.00)
        Coupons: MDAY15
        TOTAL:       $49.85
Dig that cool curvy Rondel (plaque) for my new Shoei!  Get yours from the helmet section of MAX.com
From my study, these appear to be the cause of some early failures of replacement seals from any source.  Makes sense that the seal would wear prematurely if the slider slips around under load, distorting the seal area, introducing grit, etc...
Gaiters, not my speed:
BTW I'm a convert to the Traxxion.com  "non gaiterator, flip off griterators," what are these protectors called that grip the slider and place a plastic....guard in front of the dust cap area?  My VFR showed up with what looks like an oem install.  Gaiters make sense for extending the life of seals if removed and rinsed out periodically.  but this  Traxxion gadget that deflects grit away and enabling a periodic rinse of the dust cap area makes the most sense to me.  In my youth, many were the time that I removed a gaiter to discover a puddle of grit atop my fork seal.  ok I'm rambling now.
Parts total $92 with fork oil.
Thanks in advance for any first-hand experience with Enduralast.
PS the traxxion.com website sucks.  The part that works on my K11 struts is spec'ed for a GSXR750, I only got it right because Mr. Yee Haa sent a link.  I recommend calling them as it doesn't show up on the site.  Are K1100 struts a different diameter than K75?  I have a set in hand so I'll see if they clamp well to the K75. Pictures to follow later today when I hit the shop for my first ever moto tire change.
Doing “better than I deserve"
Re: MDAY15 -K75 Strut rebuild parts- Enduralast at EME v OEM
« Reply #1 on: May 22, 2020, 11:35:50 AM »
When I had a leaking seal a couple of years ago, I took one of my SealMates and jogged it around the fork tube half a dozen times. That cleaned out particles that had infiltrated; the seal stopped leaking. You could fashion one of those from film negatives.
Offline Rcgreaves
« Reply #2 on: May 22, 2020, 11:50:16 AM »
Seal Mates is new to me.  It brings to mind a Wurth brand rubber "renewer" my GoldWing wrench used to spritz the unobtanium Carb slider seals on my OEM Honda carbs.  If memory served 4 "old stock" were about $360...  Anyway,  the rubber seemed to swell literally when bathed in this stuff.  The sliders sealed and I was in "bidnus"!  This is the seal equivalent of a fingernail file tool- who knew!
  So the negative would push bits on grit out of the seal area?? makes sense....Does a seal mate fill the gap in the seal?  I'll look it up thanks.
PS:  Im interviewing in Montreal- We could meet!  scary....
Offline Rcgreaves
« Reply #3 on: May 22, 2020, 11:51:54 AM »
sealmate.com
Laitch 1+ my friend, duh, that's really neat....had no idea.
Seal Mate - Fix Leaking Fork Seals - 1-Pack / Blue × 1
$6.99
Subtotal
$6.99
Shipping
$0.00
Taxes
$0.00
Total
$6.99 USD
Offline natalena
« Reply #4 on: May 22, 2020, 12:11:18 PM »
When we finish unpacking, I've got boxes of 35mm slides that work well too. Perhaps a "give-away" for donations to MB ... and maybe the images will have vintage rides in them. ;)
  • MST
Offline Rcgreaves
Re: MDAY15 -K75 Strut rebuild parts- Enduralast at EME v OEMv SEALMATE
« Reply #5 on: May 22, 2020, 12:28:57 PM »
good idea, though slide negatives are saltine sized, while print negatives in strips are shaped like a 6" ruler.
JULY 10 ADD- print negatives are too floppy for this chore.  Tool works well but yielded no grit alas
Either way, one hell of a tip. " Laitch the greater"  you have my fealty....
instinct says I could cancel my parts order...nah...but I'll start with the seal mate sweep or maybe I'll steal my wife's nail clean/polish kit.. :nono2:
« Reply #6 on: May 22, 2020, 04:21:08 PM »
I replaced my seals 20 + years ago and haven't had to change them since. Thoroughly clean out the area between the seal and the dust seal. Then pack heavy silicone grease between the two seals. Change out the grease every couple of years or so, more often if riding in extreme dusty conditions.
« Reply #7 on: May 22, 2020, 05:41:48 PM »
Hi Martin
Is rubber grease the same thing (Penrite, red) or at least is it suitable? And good for under the brake seals too? I always get this stuff mixed up. How thick do you  put it on?
« Reply #8 on: May 22, 2020, 07:00:21 PM »
I always use silicone grease easier to see if it's catching crap. Supercheap used to have it at $9.00 a tube Herschell silicone paste. I also pack it in as to fill all voids under rear master cylinder boots and pack it around the front master cylinder piston entrance. Although I am currently running a Chicom rear master cylinder I still have my 28 year old OEM in perfect condition in storage. I've also been known to smear it around plastic electrical connections ( not the pins) to keep out water and air which leads to oxidation.
Offline Bon Jon Bovi
  • All's well that's going ashore
« Reply #9 on: May 24, 2020, 11:17:04 PM »
sealmate.com
sealmate.net maybe, Gouda Bob?
 44271
  • Cloudcroft, New Mex
  • '93 K75s-'05 R1200GS-'08 R1200RT-'88 XR600R-'74 GT80
63 years. Don't they go by in a blink...
Offline Rcgreaves
« Reply #10 on: June 22, 2020, 05:42:32 PM »
OK OK typo on the sealmate site, oops, I suck at such details day in and out... (Get it Richard Day? RC cleaver joker ayyyy?)
It all starts with my corresponding DAILY with some airhead at high altitude Cloudcroft confusing me with a cute handle like Bon Von Jovi...that may be the only time I've typed that correctly. 44271
OK Ok so I finally parked the K75 sealmate in hand.  How does one remove the dust cap without mucking it up?
Anyway, I ran the sealmate several times and didn't see any grit come with it...drat.  I procrastinated on the seals...now I just need to "git er done"
Im going with the Enduralast parts.
In other news:
While up on the stands I'll ride my manly Interceptor 750, and do all this:
Valve adjustment  - three shims on order
Spline Lube
final drive fluid chang
Tranny oil change
Brake fluid change
Tranny Spline Lube
USB Power plug installation
replace fuel filter
Replace muffler system - got a spare for someone here!
Instrument LED upgrade
New Clutch Cable
Then... I gotta go for a seriously long ride!
« Reply #11 on: June 22, 2020, 07:35:46 PM »
Seems like I remember there's a couple of K bikes and spares about 70 clicks from The Greaves Ponderosa, you should like totally buy it all and pile it in a convenient corner Just Cause. Then start your own Patreon channel of Brick How-To vids. I'd watch.  :popcorm
Offline Rcgreaves
« Reply #12 on: June 24, 2020, 07:49:53 PM »
that 76' GL000 must be a REALLY small displacement engine.. 44271 (he had GL000 in his signature- "old age typo!"
Think of this like one of those times in a restaurant with friends and you dribble ketchup all over your shirt, a true pal leans over and says, "hey btw when you sell the bike off you can't take credit for storing it anymore!
« Reply #13 on: June 24, 2020, 10:12:17 PM »
I pulled the pistons & rods, pounded in some wood log 'dowels', added pedals and a sail. Put actual varnish in the tank to kill the gas fumes. Not another GL000 like it anywears!
 4265249878
« Reply #14 on: June 25, 2020, 01:20:34 AM »
You can cut out a Seal Mate out of a 1.25 litre soft drink/soda plastic bottle.
« Reply #15 on: June 25, 2020, 07:36:08 AM »
That's a Soda Mate.
« Reply #16 on: June 25, 2020, 04:40:52 PM »
I used a Pepsi Max bottle so it's a Maxi Mate.
« Reply #17 on: June 25, 2020, 09:35:41 PM »
. . . it's a Maxi Mate.
With a marketing name like that, you might generate broad interest.
« Reply #18 on: June 26, 2020, 12:01:25 AM »
Laitch for a small percentage you can have the US manufacturing and distribution rights. 112350
Offline Rcgreaves
« Reply #19 on: July 10, 2020, 12:36:16 PM »
Maxi Mate, Pepsi Mate trademarked with patent pending.
With wifey entering week 3 of rehab from full knee replacement I at long last spent an evening in the shop.
I have a stack of staged reassembly to do but have opted to do all the teardown steps first.  Last night it was a final drive spline check.  Though they show the effects of 83k miles they were lubed and happy after roughly 10k miles.  (skipped at tire swap last season)...
I've made a practice of maximizing the rear wheel brake application since acquiring the ABS-equipped brick. Result: a cursory rear brake pad inspection shows about 1/32" of remaining lining.."ok".
QUESTION for the opinionated and Laitch:
So, :  Brake Pads-  I know great brakes when I use them, Am I getting my money's worth buying for say EBC brand front and back for roughly $75 or can the underemployed get by with Caltric on eBay front and rear for $16 shipped (link below).    PS: All my rotors check-in spec but barely, 1.6 to 1.5.....So my thought on this is cheapo pads on the Brembo til winter and fresh rotors/pads for next season.
https://www.ebay.com/itm/Front-And-Rear-Brake-Pads-for-BMW-K75Rt-K75-Rt-750-Abs-1991-1994/282323091720?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225074%26meid%3D7cd372be192041b19959b794ee67e147%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D282323091720%26itm%3D282323091720%26pmt%3D1%26noa%3D1%26pg%3D2380057%26brand%3DCaltric&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A60491320-c2cc-11ea-8a3f-74dbd180b5fc%7Cparentrq%3A399b907d1730a688a4083fb4ffea6f14%7Ciid%3A1
My valve shims arrived. I referenced copious notes by the PO showing the #3 exhaust shim at 2.35 but alas it came out marked 2.30mm   :johnny I need to break out the caliper today and verify measurements--  pain in my a$$.
My frame support is holding my dormant K1100rs resto so I'm wrestling with the idea of waiting till winter to lube the tranny splines.  I'll probably improvise and do that too since I'm shoulder deep, and most importantly- My Interceptor 750 realllllly makes me grin!
« Reply #20 on: July 10, 2020, 03:23:01 PM »
What is the purpose of doing that?
Unless you can afford to buy another set of EBC pads when you mount new rotors, your choice would seem to be mounting a set of El Cheapos now and letting us know how it all worked out when the dust settles.
« Reply #21 on: July 10, 2020, 09:27:44 PM »
I've been using el Cheapo Volar organic Kevlar pads on all my bikes.  They cost about 18 bucks for a complete set, and they hardly wear the rotors.
Of course, my life isn't worth anywhere near what yours is, so I would advise using the most expensive sintered pads you can find and grind down those rotors.
« Reply #22 on: July 10, 2020, 09:51:14 PM »
I've been using el Cheapo Volar organic Kevlar pads . . .
Go with those, Rc. Volar means to fly in Spanish. It's almost like they're meant to be yours!
Offline Rcgreaves
« Reply #23 on: July 11, 2020, 12:41:42 AM »
Fair question:  I’ve found abs has enabled me to dive deeper into an apex and mash the binders more than I would without the abs click click click. Anyway I went through these pads faster than I would have guessed- that’s why.😬
« Reply #24 on: July 11, 2020, 08:11:18 AM »
ABS on a brick is like training wheels on a kids bicycle.  if the kid looses balance, the training wheels will keep the bike upright unless the kid really screwed up.  leaning on the training wheels is not the best way to ride a bike.    if a brick rider mashes the brake lever/pedal harder that the tires and road can take, the abs releases some pressure so that the wheels can keep turning a little for bike control.  not gonna save a rider that really screws up though.
however crude, the ABS on bricks works well for those "oh shit" moments.  I see no logic in the reasoning people use for ripping it out.
using the ABS all the time is NOT a good brake technique.  braking at the threshold of traction (before ABS kicks in) is the fastest way to stop a brick..and the safest.
and the back brake is really just a decoration in a hard braking scenario.  the back wheel is almost completely unloaded if braking hard.  front brake is where 99.9% of the braking force is generated.   rarely ever even touch the rear brake on track.
note - if loaded two up or with piles of gear on the back, the rear brake does a little more work..but the front is still doing the majority of the stopping.
cheap out on the rear brake pads if you like, but get real brake pads for the front.
