Author Topic: MDAY15 -K75 Strut rebuild parts- Enduralast at EME v OEMv SEALMATE  (Read 25763 times)
Offline Rcgreaves
Re: MDAY15 -K75 Strut rebuild parts- Enduralast at EME v OEMv SEALMATE
« Reply #25 on: July 11, 2020, 10:39:11 AM »
“Braking to the threshold of traction “-like 1300s said is more what I was trying to describe.  Thanks, and yes, I’ve found using the ABS as a tool to discover the threshold of traction has improved my riding especially after migraine from a non ABS brick.
Excuse me while I go straighten out my nose.
Still hunting for Volar ABS front and rear kit .  Are ABS and non ABS pads different?
Doing “better than I deserve"
« Reply #26 on: July 11, 2020, 01:40:39 PM »
As far as I can tell they're the same for ABS or non-ABS.  The outfit I get mine from is D2Moto.  They are a seller on eBay.
Offline Rcgreaves
« Reply #27 on: July 11, 2020, 02:23:51 PM »
Thanks for the feedback, The parts do look alike. My thought is suppliers create auctions in sloppy fashion to match search that don't necessarily match the app.  One I recall was K75 85-88 ABS etc.
order in process. Cheers!
« Reply #28 on: July 11, 2020, 04:00:57 PM »
One warning on the Volar pads. The backing plates seem to be punched with old tooling.  Probably why they are so cheap.  That makes some of them a couple thousandths oversize.  Not a big deal, it just takes a couple minutes with a file to knock off the extra metal to get a nice fit in the caliper.  They also like to squeal a bit, so a little anti-squeak on the back will make it easier to sneak up on pedestrians.
Offline Rcgreaves
« Reply #29 on: July 16, 2020, 05:10:11 PM »
So I might have pulled the trigger on the Volars but tired of hunting for the best Match of EBay auction to my year and spec.
I chose Caltric brand semi metallics made in China.  I like what they sent $17.78 shipped.
Off for 4 days, time to service the tranny splines and turn around and start reassembly in earnest.
Offline Rcgreaves
« Reply #30 on: July 18, 2020, 11:15:02 PM »
Mahle Air Filter $40.47 shipped Euro Moto Electrics ... No sense in syncing my throttle bodies, valve shins etc without a fresh air filter.
Cancelled July 19 - Amazon much better deal per Gryph.
Offline Rcgreaves
« Reply #32 on: July 19, 2020, 01:32:30 PM »
$29.31 after tax.  Thanks Gryph!!
I think this idea for shim removal is brilliant- compressed air!
 I can’t endorse some of the other klugey stuff like grinding shins to size.... He compresses the spring with a screwdriver...Maybe on the side of the road in Alaska, but never for a first experience like I just enjoyed. Buy the spring tool forevermore!! I spent a lot of time getting comfortable that I was measuring etc accurately not confusing SAE and Metric tolerances, revisiting Youtube. Nevertheless, the compressed air is an elegant solution worth sharing.
Offline Rcgreaves
« Reply #33 on: July 19, 2020, 10:38:40 PM »
Valve adjust done.  Compressed air for shim release from oil suction inside bucket +1 .  Included a pic of the shim popped loose behind the cam🤣! Fast.  Look how much of an oil puddle sits behind the shim even after a month.  Pretty frustrating fighting that with a pick and scratching stuff in the klugey process..Compressed air instantly breaks that suction seal.  Video added 7/24. bad mechanic, spark plugs last....
 Most crank the engine for valve adjust with hex sections cast into the cams, I prefer a 5mm hex head turning at the ignition trigger, a ratchet there is more precise than clanging away with a combination wrench  all props to Chris Harris.... on the cam and dinging against the case to valve cover sealing surface.
another side track--
Last fall I tipped in a parking lot scratching the corner of the valve cover, so I carefully filed sanded buffer sanded and repainted.
Mititoya pro grade digital caliper and Chinese manual compared and measured very similarly.  For giggles I compared Harbor Freight cheapo caliper.  Unacceptable readings- sufficiently inaccurate it would create more problems... shit canned that- don’t need 3 dial calipers.  Mitutoya is about $70 -a good investment.
A month later and I have yet to sort the front struts that got me started here.  That will come last.
Offline Rcgreaves
« Reply #34 on: May 28, 2021, 11:49:29 PM »
Its been nearly a year since I worked actively on my K75. Shoulder surgery, so much COVID TV to watch.  Actually, I've restored a couple of other bikes so here goes:
The shop is cleaned and the parts are laying out like surgery.  I didn't address lubricating my clutch splines, so I sprang for a fresh friction disk and the requisite hardware necessary from MAX.  With my K1100 still occupying my support, I'll have to come up with a second support apparatus before I can remove the transmission.  pictures Saturday. Cheers.
