Author Topic: Hydraulic clutch conversion  (Read 6652 times)
Offline MEZ
  • Never surrender always busy
  • once dead soon forgotten dream big aim high
« on: May 07, 2020, 02:10:08 AM »
Hello Brickers, have some patience and read on please, a bit long winded but I needs your helps (for you that Johnny..!!). Basically I have had a Magura hydraulic slave cylinder in place for last 4 years while building my project bike (K75gsa) and it has just failed quite epically. We are going to fit a Wilwood unit (of USA origin) which is a bit more up to the job. My quandary is this, nothing to do with hydraulics, we'll sort that out when the unit arrives. We are going to retain the cable option as a fail safe 'get me home' standby if the hydraulic syatem fails whilst travelling. The cable will sit in place and be implemented roadside should it be needed.
In place currently is a BMW R1200GSA '2006' master cylinder. What I need to know, what BMW cable operated clutch lever assembly will fit on the bars whereby I can retain the top clamp half from the current R1200GSA fitted..?? Reason being is that I don't loose the fitting aspect of the hand guards and replacement is a two bolt affair roadside. SO GENTS (and ladies) any Brickers out there that have an '06,'07 or '08 1200GS and an older Beemer with cable clutch and can offer up the top clamps for comparison ???? Basically I need to know if the thread centres are the same and it holds firm ???? Hope this made sense....
  • Angel of the North
  • GS12adv '06, K75 GSadv, CRF500L 'special'
Re: Hydraulic clutch conversion
« Reply #1 on: May 07, 2020, 07:23:12 AM »
Photos would help here, MEZ.
Offline MEZ
« Reply #2 on: May 12, 2020, 12:17:05 AM »
Sorry no photo's again Laitch but another clutch related (BMW) question if I may. I'm using a high end Wilwood clutch slave cylinder on my K75 build ( The Magura unit failed) which has a 7/8" piston bore. Anyone on here extremely knowledgeable on bmw clutch master cylinder piston sizes and can get me as close to 22mm as possible. Brembo do a 19mm with 18/20 variable setting click adjuster but I'd prefer to keep within the bmw brand and buy a 2nd hand unit.  19mm anyone...???
Offline DJEwen
« Reply #3 on: May 13, 2020, 04:57:15 AM »
 :useless
  • Scotland
Offline k
« Reply #4 on: May 15, 2020, 08:48:25 PM »
I'm not a fan of hydraulic clutches. Cables work fine and have much less maintenance.
  • Indiana
Offline SJK
« Reply #5 on: August 21, 2026, 08:02:48 AM »
Hi MEZ , wondering if you resolved your issue? Im thinking of converting my cable to hydraulic as well.
  • Cape Town ,South Africa
  • K75 1989
