I had a heck of a time getting the front brakes air-free on the new-to-me K75S. I don't know your full setup, but I have OEM Showa forks with Brembo OEM calipers and ABS-WON reinstalled. The master cylinder pumps fluid to the left-side pressure modulator by the rear wheeel, then back to the right front caliper, with a steel crossover line to the left front caliper. Only the left side has a bleed screw, as does the modulator.
All the rubber lines were replaced with Spieglers, and I could not get any pressure to build even using the Mighty Vac. I was getting only air-free fluid at the modulator so I concentrated on the calipers. I even took the calipers off and turned them to different positions, thinking air was trapped in the steel crossover line, but still no pressure.
I noticed using the Mighty Vac that I kept getting air bubbles when I shouldn't so tried these two things: I trimmed the end of the plastic hose to get a tighter fit on the bleed screw, and I removed the screw and put teflon tape on the threads and reinstalled it. That got me to where I was only pulling fluid at the calipers.
I had to go back to the modulator at this point but didn't use the Vac, just the old pump-and-crack open method. And instead of a slow pump I pumped like mad. More air suddenly burped out and the lever started to firm up. I did this till five more pump cycles produced no air bubbles, and now the lever is very firm.
If you don't have ABS then some of this is moot, obv. And in the link Laitch provided is an admonition to slowly pump the brake lever and watch for bubbles coming from the bottom of the master cylinder while tapping here and there to free up any trapped air. I think that may be all-important to getting air farther down the system moving toward the bleeders.
Hope this helps, my curse jar had to be emptied and started over on this one.
