Author Topic: Tipping over!!  (Read 5516 times)
Offline Thomas
Tipping over!!
« on: December 06, 2019, 11:53:27 AM »
Hi All, New here! Bought a 1991 K100RS, about a year ago. Had to have some work done on it before it was road worthy. Soon after getting on it for the first ride. I discovered it wants to fall over when trying to turn around slow. Or when you come up to a stop sign, or behind a car. Is this normal for this bike?? I can't believe that it is! I was trying to turn around in a parking lot, at a campground I was staying at. The damn thing started to go over! I couldn't stop it from going! Threw me on the ground! Messed my leg up pretty good! I love the bike when I get it moving. But, this feet down turning issue, ain't good!! Anyone else having or heard of this problem?? If so, I'd appreciate any ideas of what is causing it. And how to fix it. If I can't figure it out, and straighten it out come spring. I'm afraid it will go back on Craig's List. I'm 67 yrs old...can't be doing this tipping over stuff any more!! Thanks for any thoughts about this!! PS: Come spring I'll be replacing the steering head bearings, and fork seals.
  • Middlebury, Vermont USA
  • 1991 K100RS, 1976 KZ900, 1971 Triumph TR6C, 1980 KZ1300
Re: Tipping over!!
« Reply #1 on: December 06, 2019, 12:04:10 PM »
the reason your motobrick wants to fall over is because the forces of top heavy balance and gravity...
its same thing for slow manuvering plus the forces of motorcycle gyroscopic effect...
look... the goal is to be able to do slow figger 8s in a space of 4 parking spaces... start with 8 spaces and get it down to 4... it takes counterbalance slipping clutch back brake...
you do that daily until its involuntary... then you can pull a fog line to fog line u turn on a narrow country road feets on pegs one fluid manuver...
look here... www.motobrick.com/index.php/topic,154.msg174.html#msg174
setts you up a cone course in a parking lot... you can getts the layout here... www.msf-usa.org
its a crazy world... butts you already knew that...
Re: Tipping over!!
« Reply #2 on: December 06, 2019, 12:09:20 PM »
K bikes tend to be a little top heavy and that's exaggerated if you're short of inseam or weak/bad knees.  There are some tricks for lowering the bike, that may help.  Otherwise it's just something to adapt to or buy something less tippy.
Re: Tipping over!!
« Reply #3 on: December 06, 2019, 01:09:47 PM »
There are techniques for slow manoeuvring. There are multiple sites showing how on the web, once viewed find a large flat area and practice. In OZ there are also courses that you can do on both high speed and slow speed very worthwhile. Are you able to flat foot? If not there are various things that you can do.
Re: Tipping over!!
« Reply #4 on: December 06, 2019, 01:12:08 PM »
Avoid using the brakes when moving slowly with the front wheel turned, especially the front.  Also, make sure the throttle position sensor is adjusted properly and the throttle bodies are balanced to minimize notchy throttle response.
Have you checked the fork oil?  Changing the oil and adding the proper amount helps a bit with the front end dive that contributes to slow speed drops.
Also, look at things you can do to lower the bike.  If you can find one, Worx performance shocks, can be rebuilt and lowered at the factory for a reasonable price.  I have my K75 lowered 1/2" with a Worx shock and the forks pushed up in the triple clamps.
Having said that, I still have a drop every year or so.  I look at it as part of the K bike experience.  I ride about 8-10,000 miles a year.  I'm 71 and 6' tall and like to think I still have another five or six years of riding left in me.
Re: Tipping over!!
« Reply #5 on: December 06, 2019, 01:38:58 PM »
Try here for a training course.https://dmv.vermont.gov/young-drivers/vermont-rider-education-program-vrep There are heaps more sites dedicated to slow manoeuvring. https://www.ridinginthezone.com/how-to-ride-a-motorcycle-slowly/
Re: Tipping over!!
« Reply #6 on: December 06, 2019, 02:21:15 PM »
Hi All, New here! Bought a 1991 K100RS, about a year ago. Soon after getting on it for the first ride. I discovered it wants to fall over when trying to turn around slow. Or when you come up to a stop sign, or behind a car.
Come spring, let's get together and see about improving this. Your youth and experience won't bother me. In the meantime, this is how it's done.
Offline drut
Re: Tipping over!!
« Reply #7 on: December 06, 2019, 03:02:08 PM »
I have 1990 K100Rs16v and at 71 find I have to be careful,although no problem at walking speed up over it can(especially with full fuel tank)catch me out when paddling around garage or whatever.If it tips past a certain point I cannot stop it and need help to lift it back up but I have never had any issues pulling up to a stop at junctions etc.If memory serves me correctly there were some "drops" when paddling about by journalists on the K1 launch and it is nearly the same bike apart from cosmetics.
  • Newcastle upon Tyne UK
Re: Tipping over!!
« Reply #8 on: December 06, 2019, 05:01:54 PM »
Make sure the handlebar is straight when stopping, and you won't be dropping it anymore at stop signs. The video's are good,  I think the best tips with turning is practice slipping the clutch to get the lean angle right, look ahead and counterbalance with your body.
I recon to be initiated into Brickdom you have to have dropped it at least once on the right hand side.  My five bricks all have before I got them and I've done a few too. It's the "schmiss" of Brickdom,  I wear the battlemarks with pride on the right hand crash bar.
Offline Past-my-Prime
Re: Tipping over!!
« Reply #9 on: December 06, 2019, 10:56:15 PM »
It gets better. Mine has gotten tired and needed a nap occasionally; probably half a dozen or so times in 23 years. Always at slow speed. I can u-turn it on a narrow road but it takes some active leaning and judicious throttle.
This is a bike you need to "stay ahead of" and know where it's going.
I think I've had it go over twice when I was astride it.  The rest of the time when I'm getting it onto the centre stand and am not quite centered.
It's a price I'm willing to pay for a bike that feels so right any time I'm over parking lot speeds.
Offline Thomas
Re: Tipping over!!
« Reply #10 on: December 07, 2019, 01:27:32 PM »
Hey Everyone, I want to thank you all for your reply's!! I've learned a couple of thing here. One, I've got to live with the top heavy feeling of this bike. Two, learning about the friction zone!! I've watched a couple of the video links already. Very interesting!! I have ridden several bikes over the 50+ yrs. that I have been riding! Have to admit...I have never used the friction zone in quit the way these gentleman have explained. Looking forward to spring! Getting the new steering head bearings and fork seals installed. And putting the friction zone theory to work for me!! Thank You all again!! PS: Liking this forum!!
Offline alabrew
Re: Tipping over!!
« Reply #11 on: December 07, 2019, 01:56:24 PM »
The dry clutch makes it a bit more difficult. Using second gear is another option as is shifting your butt to the outside of the turn.
The instructors at the Motorcycle Safety School Open House Rodeo are always telling me to turn my head further into the turn.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
