Author Topic: 1987 K75 poor running  (Read 30954 times)
Re: 1987 K75 poor running
« Reply #25 on: October 31, 2019, 12:30:09 AM »
The way I understand this problem is that your motorcycle starts and idles OK but bogs down when opening the throttle.  Is this correct?
I start with basics, it sounds like too much or not enough fuel or a weak spark which may be caused by multiple problems.  Knowing the basic problem will help guide the diagnosis.
Although the plugs are new, what do they look like after it bogs down?
Offline volador
  • NEEDS MORE CHROME
« Reply #26 on: October 31, 2019, 02:23:39 AM »
Is the petrol tank venting properly? During moto idling if you open the petrol filler cap is there a pronounced "Swoosh" of a lack of air in the tank?
If so may have a blocked tank vent http://www.motobrick.com/index.php/topic,12374.msg109410.html#msg109410
There is also a grounding point on left side under the tank
"The PO had also replaced the fuel injectors."
Verified fuel injectors are working properly?
Verified ignition timing? Hall Effect Sensor?
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #27 on: October 31, 2019, 08:05:15 AM »
Do the spark plugs have terminal nuts???   NGK plugs don't come with them.  That's why I asked for photos,  to confirm that you have them.  The bike won't run for shiite without them if you still have the original wires.
Offline volador
  • NEEDS MORE CHROME
« Reply #28 on: October 31, 2019, 11:50:21 AM »
You dab any green threadlock on those sparkplug caps?
Ever have one loosen up on the road?
Any change in moto performance?
  • NYC NY
Offline kenrams
« Reply #29 on: November 02, 2019, 05:12:40 PM »
Solved!
Thank you, everyone, for your comments and help. It was a great learning exercise for me to go through the bike in what I thought was a logical step by step procedure. I hate it when threads just end with no solution, so I will eat a bit of humble pie and reveal the actual problem. https://www.motobrick.com/Smileys/default/donkey.gif
I pulled the spark plugs and checked for a nice big spark and sure enough, I had that on all three. They were all sooty and a little bit wet - not good but I moved on to the next thing. I should have dug a bit deeper when I had them out the first time. Like a few of you suggested I went back to the start this morning after I fitted the radiator back on and that's when I found it - HT leads for 1 & 3 were swapped !! Not sure when that happened but maybe I got it that way or I did it during my investigation. Just took it out for a short spin and it feels great.
Thanks a lot everyone
  • Asheville, NC, USA
  • 1985 K100, 1990 K75, 1982 R100
Offline caveman
« Reply #30 on: November 03, 2019, 06:50:34 AM »
Glad you found the problem and thanks for giving it up, I have done things like that too.
  • Kennerdell, PA.
  • 87 K100RT, 88 K100LT
« Reply #31 on: November 03, 2019, 12:51:38 PM »
Thanks for the update!  That foldback on the #3 wire(#4 on the k100) has fooled a lot of folks on their first spark plug change.
« Reply #32 on: November 03, 2019, 01:04:04 PM »
Thanks for running this thread to conclusion.
Offline beemuker
« Reply #33 on: November 03, 2019, 02:24:24 PM »
Good for you. Some threads are never concluded. My flashers are acting up again. good grief! I'm just using hand signals till it gets too cold to ride, then I'll revisit the whack.
  • Panama City, FL
« Reply #34 on: November 03, 2019, 03:06:43 PM »
Another thank you for including the solution.
Offline volador
  • NEEDS MORE CHROME
« Reply #35 on: November 05, 2019, 10:06:09 AM »
Foldback wire #3 should be looped as such to prevent kinking
  • NYC NY
