Author Topic: Some days trolling Craigslist go better than others.  (Read 45836 times)
Offline Rcgreaves
Re: Some days trolling Craigslist go better than others.
« Reply #26 on: January 06, 2023, 04:41:47 PM »
Happy New Year Griph:
So all 24 bobbins are identical...the OEM sources have 3 of 12 with a spring of some sort. Methinks my Johnny source had the hot ticket with maybe harder steel bobbins?? What's the OEM function of the diffrent bobbins spaced around the ring? Just Curious....
Doing “better than I deserve"
« Reply #27 on: January 06, 2023, 06:58:00 PM »
I seem to recall that the bobbins with the rings were intended to dampen any rattling of the rotor.  I guess that the regular bobbins can't hold it in place securely enough.  The idea is that there is little or no radial play in the rotor attachment, but a little runout play is designed in.
My first 16V RS didn't have the bobbins with the rings, and the rotors made a jingly, rattling sound going down the road.  The rotors have to be able to float side to side a tiny bit to prevent brake pulsing, but if they are not damped with a little bit of friction they rattle.
Offline Rcgreaves
« Reply #28 on: January 07, 2023, 12:01:25 AM »
Back in 2019 I made inquries. The parts were sourced from Motobins. Each Bobbin has an oversized spring washer.  Super results.  I believe the bobbins are stainless steel.
« Reply #29 on: January 07, 2023, 07:57:56 AM »
If they're stainless, I would keep an eye on wear in the cutouts the bobbins go in.  The originals were aluminum so they wore rather than the rotor or the carrier, making them the wear part of the assembly.
Offline Rcgreaves
« Reply #30 on: January 07, 2023, 11:33:48 AM »
point taken on the wear points for the bobbins.  I might not have my facts straight on the materials.  Johnny has been running these a few years- Yo Audiology man, you out there?   Reviews at Motobins were positive....NTL, stainless is harder than aluminum... Pray
Gryph thanks ever so kindly for scouting that edging.  I want to verify the diameter of the trashed components as I think the diameter of the foam insulator tube is bigger on the worn out edging.... I'd hate to drop that much money and discover it doesn't touch the fuel tank.  Then again the red paint is rubbed off from this current OEM stuff so perhaps a smaller diameter that DOESN't ride against the fuel tank would be better.... :idunno:
Also: I have a K1 runner stashed that will come apart in February for my third K clutch...it will probably require something similar...
In my day job...errrr.....early morning and late afternoon job I drive a school bus....the company is owned by an auto body shop.  At tonight's holiday feast I'll bring along pics and sizing and talk to the part's guy about what they stock.  If I can supply extra Gryph,  I will.  Cheers.
Offline Rcgreaves
« Reply #31 on: January 07, 2023, 11:46:03 AM »
You selected very well Gryph, the specs match up.  I'll be in touch after I sleep off the party.  Cheers.
« Reply #32 on: January 07, 2023, 02:23:47 PM »
Lucky guess on my part.  You might try looking for a smaller quantity to get a lower price.  I saw it on some U.K. websites for about 10 bucks a meter.
I would think you could start a thread here to sell some to the inmates.  MaxBMW shows it as NLA on the parts lists and I know that I've had to replace a bunch of it on my bikes.
Offline Rcgreaves
« Reply #33 on: January 07, 2023, 02:29:33 PM »
gotcha....I'll research a wholesale buy tonight.
