Author Topic: 1985 K100RS start mystery  (Read 40588 times)
Offline robleyd
Re: 1985 K100RS start mystery
« Reply #25 on: October 30, 2011, 07:16:43 AM »
Curious minds want to know why you felt the need to quote the image?
Motobrick member #70
1996 K1100 LT
1969 Triumph Bonneville
Offline Lawrence
« Reply #26 on: October 30, 2011, 11:31:30 PM »
That diary story is a hoot -- and comes so close to reality its scary.  Plus, there's the bonus of a pix of a lovely lady.  Thanks!
I've invested another entire weekend in the RS.  However, I'm going to sleep happy this time. In the course of fitting some of the Euromotoelectric high quality electric cables to the bike I discovered my wiring error.  It's such a stupid mistake its not only an embarrassment, but it has me thinking I should restrict my personally-done maintenance to adding air to tires.  I am fully capable of doing more harm than good in any given situation.  :-\
On the bright side, I've learned a lot.  Thanks for the many helpful hints and suggestions.  This is a valuable resource for a new flying brick owner. Crawling up the steep learning curve has also given me a warm and fuzzy feeling to balance the frustration I've brought on myself because I'm now pretty sure that the 25 K miles on my 1985 K100RS is pretty close to reality.  The splines are virtually new; when I stripped the ignition switch for cleaning and inspection I found very little wear there too. The only weak point on the entire motorcycle seems to be the rust and corrosion on the frame and alloy surfaces.
 Looking to the near future, I would like to fit heated grips and a headlight relay. Then ride her til I can't throw a leg over her any more. Do I dare tempt fate again...?
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
Offline CRASH
« Reply #27 on: October 31, 2011, 01:51:45 AM »
Same reason I quoted this ... so the clueless masses will know what I am responding too.
- CRASH -
Offline robleyd
« Reply #28 on: October 31, 2011, 03:33:41 AM »
Quote
the clueless masses
Didn't realise that any of our august group fell into that category ::)
1996 K1100 LT
Offline CRASH
« Reply #29 on: October 31, 2011, 09:52:09 AM »
Quote
the clueless masses
Nor did I realize it would be necessary to explain why one quotes a post to this intrepid group of anti-pirates.  Apparently the answer is yes on both counts.
- CRASH -
Offline kennybobby
Don't leave us hanging--what was it that you did?
« Reply #30 on: October 31, 2011, 10:03:45 AM »
Share the discovery please... it helps to know what not to do.  Everyone that put time in trying to help deserves at least that much.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
Offline Lawrence
« Reply #31 on: October 31, 2011, 03:32:56 PM »
Okay, okay I'll come clean.  I was trying hard to avoid being the goof-up poster boy but if you insist (and promise to keep this under your hat).  There are two spots on the left side of the engine where an electrical wire can be connected.  I managed to put the ground wire on the wrong one.
Okay, now I have to go under deep cover....
1985 K100RS
1983 BMW R100RS
Offline robleyd
« Reply #32 on: November 01, 2011, 04:58:48 AM »
Quote
the clueless masses
Well, not to drag this out but there are times here when people quote a post with one or seven images in it which seems overkill to me; and tends to give my older machine/browser a hard time. I do understand quoting, I just don't understand over-quoting. Whatever, I'll not say any more on the topic lest it be misinterpreted.
1996 K1100 LT
« Reply #33 on: November 01, 2011, 11:28:24 AM »
the new forum software that we are upgrading to has a feature where only text will be quoted... not images... yeeeeehaaaaaaaaa...
and for you photo conscience attachers... 1024px × 768px should be max size... this system will not limit the height width... the new system will...
so until we upgrade please keep images to 1024 x 768 or less...
Offline Lawrence
« Reply #34 on: November 01, 2011, 09:52:26 PM »
Halloween is behind us.  Please retire those pix  :(
1985 K100RS
1983 BMW R100RS
« Reply #35 on: November 02, 2011, 09:29:54 AM »
Thank you.
Offline blakey
  • Learn to listen, listen to learn.
« Reply #36 on: November 05, 2011, 05:33:02 AM »
You guys crack me up! ;D
blakey
K100RS 1986 RED!
North of Bris Vegas, Queensland, Oz.
Offline Lawrence
« Reply #37 on: November 05, 2011, 08:41:27 PM »
This is too much like 2nd grade.
1985 K100RS
1983 BMW R100RS
« Reply #38 on: November 05, 2011, 08:47:43 PM »
i skipped 2nd grade...
« Reply #39 on: November 05, 2011, 11:00:19 PM »
No, it skipped you. 8)
Offline motodude
« Reply #40 on: November 05, 2011, 11:20:56 PM »
Nancy is scary enough w/o the makeup.
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
