Author Topic: Had an unplanned get-off...  (Read 11768 times)
Offline beemrdon
Re: Had an unplanned get-off...
« Reply #25 on: March 14, 2019, 10:25:47 PM »
Thanx Bizz, I can only play with it on weekends. Working 8 to 5+ these days.
I'll let you know how it turns out.
BTW, what part of Vt do you live? I used to live up there a long time ago. We had a dairy farm in Fairfax and another one in Richmond.
I attended Johnson State College for a couple of years.
Time to milk the Kaawouz, aaaa-up
Offline bizzaro
  • co pilot
« Reply #26 on: March 15, 2019, 08:24:12 AM »
Yep, same neck o the woods! Pretty sure I know you! JSC is just down the road from me.
  • Vermont
See Ya in the Twisties,
 Bizz
Offline beemrdon
« Reply #27 on: March 15, 2019, 05:34:47 PM »
That't pretty cool, but I don't remember any Bizzaros, well I guess I should rephrase that..
I may come back there to live before I kick it. Anything's possible but those winters are loooooooooooong.
Offline beemrdon
« Reply #28 on: March 17, 2019, 12:09:57 AM »
It's Saturday morning and I re install the "brain" and re attach the battery ground cable to battery. Hope that does it.
I start the bike and then get the alternating abs lights again. Damn!
Ok, so then I go and get the wire with a gator clip on each end.
I attach one end to the 3 pin test unit, via a brad shoved into the middle hole and then clip the gator clip to it.
Next, I attach the other end to battery ground terminal.
Then I turn ignition key to ON and push in the abs switch and count to 10...and then...I let go of the abs switch and  I see that BOTH abs lights are blinking in unison. Awesome...
So I go take the bike out for a spin and jam on the rear brake and no sliding.
The abs is re set. Yeehaw!
Finally, I go take the K11 out for a couple hundred mile ride.
Thanks to everyone for all of your suggestions. I could not have done it without you!
Offline scottsdot
  • Non quom non paratus.
« Reply #29 on: March 17, 2019, 04:33:50 AM »
A brief story on water damaged gear: So, my first real job in the eighties was as an apprentice Telecom tech up Cape York, replacing the old 4 wire line on posts with a modern microwave repeater system. It was at the stage where it needed testing and we had some very expensive test gear. Some kindly Bamaga tech decided to provide us with a busted up shitty ute to load our gear into. It rained a lot, gear got wet. When we set up camp that night, my boss opened the test gear up and it would not function. Error codes. He unscrewed the cover and suspended the circuit boards over a gas stove, about 6 inches up, and moved it around patiently to aid evaporation. I was laughing and having a beer. I thought, no chance. I was wrong. It fired up fine after this exercise.
So when old mate says "I am highly suspecting there is water in my ECU?  Is there a way to check for water.  Can it be fixed if it is?  And can I do it?", the answer may well be to provide patient, subtle heat to aid evaporation, as in the above. Just an idea.
That was a good job that one. No more frontiers left unfortunately.
  • narangba, qld, australia
  • k1100lt
K1100LT 1992, Susie RF900F 1994, Yammie XJ600 1985, Ford Falcon Ute AUII 2000
« Reply #30 on: March 17, 2019, 11:37:54 AM »
Toshi is the man!!!
